Old 05-09-2007, 01:47 PM   #1 (permalink)
Default how to broke power on password
hi frnds, i have problem with ma pc
when i start ma pc it ask me the power on password
and i dont knw wats the password is
can anyone help me how can i broke ma password and run my pc
even i putt off the cell from the motherboard, but does no effect
plz help me
SMARTLUBANA is offline
Old 05-09-2007, 01:50 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: how to broke power on password
You need to reset the BIOS using a Jumper, just removing the battery wont work. Just do a search in the forum you will get lots of threads related to resetting the BIOS.
Take a look at this PDF file ( Direct Link )
EDIT: Reporting as its not in correct section.
Charan is offline
Old 10-09-2007, 08:48 PM   #3 (permalink)
Chetan1991's Avatar
Yeah,he is right.Open your cabinet and you will find 2 pins near the ROM with "short" and "open" written near them.Just join them through a jumper(or even connecting them with a wire also works don't try this if you are not sure!!!) and turn on the computer.You will see the message "checksum error-Defaults loaded" and BIOS will reset.
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
ATI M.R. HD 5450 1GB
298 GiB 7200rpm WD hdd
LG Optimus One P500
where-go-for-6-week-industrial-training?
Chetan1991 is offline
How can I reset the BIOS Power On password? ashisharya Software Q&A 9 28-10-2007 10:39 AM
Power of America & Power of India - Awesome [large pics] s18000rpm Chit-Chat 13 25-07-2007 04:49 PM
Broke bootable XP Media Center CD. ::HELP:: aditya1987 Software Q&A 8 01-12-2005 01:54 PM
HELP CD-RW Broke my cd into pieces!!!!!! naveenchandran QnA (read only) 5 27-03-2005 06:05 PM
