Old 03-09-2007, 10:45 AM   #1 (permalink)
Exclamation Norton antivirus problem
hi i am facing one problem i am using norton 2003 with latest updates when i am scaning my system it shows some viruses but it also displays access is denied like that plz help me how can i solve this problem
Ravi.Y
yrakesh78 is offline
Old 03-09-2007, 10:58 AM   #2 (permalink)
Cool G5's Avatar
Default Re: Norton antivirus problem
when does it shows access denied?when u try to open the infected file?Make ur query more clear by posting screenshot.
Cool G5 is offline
Old 03-09-2007, 11:34 AM   #3 (permalink)
Try to scan ur pc in safe mode
:P If U lIkE mY SUggeStIon Plz ADd SOmeThing tO mY RePUtaIon :)
buntythecool is offline
Old 03-09-2007, 01:46 PM   #4 (permalink)
Gracias Senor
dreams's Avatar
Gud..Start in safemode..
In run type "navw32 /l" - witout quotes, last character is l as in larry.
Check.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 03-09-2007, 06:07 PM   #5 (permalink)
Are you scanning using a limited account? Or if the file system is NTFS, some other user account on your computer may have encrypted that file. or the file may be password protected using any software
ThinkFree is offline
Old 05-09-2007, 11:42 AM   #6 (permalink)
Mobile Freak
reddick's Avatar
NORTON suxs a lot There r also free AV(s) available...try AVG or Avast 4.0 with latest updates U will gt gr8 protection n they r also light on ur system Hope it will works for u
Hope 4 d best n Do d right :)
reddick is offline
Old 07-09-2007, 05:07 PM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
login as admin .......
... W H O T ...
ax3 is offline
Norton Antivirus 2005 LiveUpdate Problem devil666 Software Q&A 2 11-10-2005 02:00 PM
Norton Antivirus 2005 vs Symantec Antivirus Corporate Curious Guest Software Q&A 1 23-04-2005 08:37 PM
Norton Antivirus query .. hbk85 Software Q&A 2 17-12-2004 11:02 PM
AVG 7.0 vs Norton Antivirus Choto Cheeta Software Q&A 9 30-11-2004 08:26 PM
Problem With Norton Antivirus 2003 FasTrack Software Q&A 6 21-10-2004 10:37 AM
