Old 31-08-2007, 10:50 AM   #1 (permalink)
sharma_atul85's Avatar
Exclamation xp booting problem
hello frns im havin dual boot of win xp n fedora 3..last nite ven i was transferring sme data to my pen drive...d screen got black ...only cursor was there...i tried to recover it usin ctrl+alt+del n like dat but all in vain...then i restarted my PC..nw it shows
verifying DMI Pool data......
No Bootable partition in table
later on ven i restarted it ..it shows
Verifying DMI pool data.....Update success
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
help me!!!!
sharma_atul85 is offline
Old 31-08-2007, 09:48 PM   #2 (permalink)
lalam's Avatar
Default Re: xp booting problem
Hmmmm no reply here. Well do what it says if you have the installation disk insert it then reboot then run the fixmbr command under recovery console (not the automated system recovery), thats as far as i can suggest. See if it helps.
lalam is offline
Old 01-09-2007, 04:40 PM   #3 (permalink)
Chetan1991's Avatar
Only some days ago I came across the message:
The reason behind it was that IDE cable had loosened a bit i.e. connection from HDD couldn't be established and the owner hadn't given the CPU any jerk or somethink like that.
So try it once,hope it'll work.
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
ATI M.R. HD 5450 1GB
298 GiB 7200rpm WD hdd
LG Optimus One P500
where-go-for-6-week-industrial-training?
Chetan1991 is offline
Old 06-09-2007, 05:54 PM   #4 (permalink)
o yes dude it solves my problem... thnx..
Problem booting XP opokharel Software Q&A 1 09-02-2007 12:45 AM
booting problem gau_pppu Hardware Q&A 2 23-11-2006 01:52 PM
Booting Problem vineetrocks2005 Software Q&A 4 19-05-2006 11:05 AM
Xp booting problem. sagar_coolx Software Q&A 3 30-04-2006 12:08 AM
booting problem gvrappu Open Source 5 29-04-2006 11:57 PM
- by chris
