30-08-2007, 03:36 PM
Pee into the Wind...
Which is the best screen capture utility??
Hi everyone!!
I always used FSCapture for my screen capturing needs till now as it used to be a freeware.But now those blokes have made it a paid software  .So I need some other freeware for this purpose.Can you guys post the links to screen capture softwares you use so that I can try them out and decide which one best suits my needs.
Regards,
shady_inc
Life is as complicated as you say it is.
30-08-2007, 03:50 PM
Re: Which is the best screen capture utility??
30-08-2007, 04:17 PM
IRFANVIEW
and if u wan 2 do it with vdo files use VLC media player
both FREEWARES
30-08-2007, 05:33 PM
Šupər♂ - 超人
for screenshots, the best & free method.. still.... is PrintScreen button & MSPaint
30-08-2007, 05:41 PM
The Frozen Nova
^^ I second it. Snippy in Windows vista
www.nerdweed.blogspot.com
30-08-2007, 05:51 PM
Šupər♂ - 超人
^^^^ I second it
30-08-2007, 05:53 PM
irfanview
30-08-2007, 06:01 PM
I use printscrn button.Irfanview is good.
30-08-2007, 06:28 PM
IM AS MAD AS HELL!!
use Jing!!!
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
30-08-2007, 06:31 PM
gooby pls
31-08-2007, 12:12 AM
print screen button + irfanview
Incompatible message format
31-08-2007, 12:19 AM
 wat is d point of using print screen button wen u usin Irfanview
Irfanview has its own capture key Ctrl+F11 (default 1)
31-08-2007, 12:27 AM
got used to the print screen key before i started using irfan view
replaced paint with irfanview coz it got better options while saving. you know, the quality and stuff
31-08-2007, 10:04 AM
THe best I found is clipmate it captures not only screen but every thing on the clipboard even text. I Used that when I was developing my site & found that I could copy multiple text on the clipboard & later after 2 days I could paste that where ever I needed.
31-08-2007, 01:44 PM
mera kutch nahi ho sakta
Any commandline tool for windows?
jin files ka koi server nahi hota unka bittorrent hota hai
31-08-2007, 06:20 PM
Originally Posted by Tech Genius
Winsnap
Winsnap is not a freeware friend.
Printscreen doesn't capture scrolling windows or any particular area on screen.
02-09-2007, 10:15 AM
I am also using Screen Hunter from Wisdom Soft for several years & it is really good. I would like to know if any freeware for capturing the flash movies from web pages.
C_Nagaraj
02-09-2007, 10:20 AM
if u referring to youtube or metacafe or google videos den u can use
Ook? Video Ook! 0.6.6
to save d vdo on ur HDD
if u wan2 dwonload d vdo using a dl manager den u ca paste d url in youtubex.com
(for downloading from other sites check d top menu in youtubex)
02-09-2007, 10:37 AM
#19 (permalink)
with print screen button on your keyboard you cannot take screenshot of a movie, but with this software you can...
HyperSnap DX, just give it a try, you won't be dissatisfied with it.
http://www.hyperionics.com/
02-09-2007, 10:44 AM
#20 (permalink)
FRAPS is da best. But for streaming movies larger than 5 sec, u need to buy it
G3: XPS M1530 |
FZ 16.
02-09-2007, 11:18 AM
#21 (permalink)
a_g = JPKN
oops, its not for free
ASUS K53SV SX520D + BF3
02-09-2007, 02:08 PM
#22 (permalink)
Quite a lot of support for PrintSceen and irfanview Combo !! Yahooo!!! i am for it too , been doing it for last 3 years !
Beware of my Wrath Mortals, Thou hast no choice.
02-09-2007, 03:33 PM
#23 (permalink)
Most of the media players have the option of taking a movie screenshot.Why buy a separate software for it??
02-09-2007, 04:24 PM
#24 (permalink)
though it's not freeware ashampoo magicalsnap is good and you can get it from this years april dvd or it can be in other issue of digit register it and it will be your full version
02-09-2007, 04:53 PM
#25 (permalink)
IM AS MAD AS HELL!!
with Jing you can Capture FLASH movies !!!
i love Jing
www.jingproject.com
02-09-2007, 04:54 PM
#26 (permalink)
well i am looking out for a program...thru which i can make video....like how they have instructional video to teach softwares...but also the, video i make should be small in size...last it should be a freeware
06-09-2007, 12:15 PM
#27 (permalink)
i have used kind of screen capture software called ACA Capture Pro, i think it can handle it .
here is an article about it:
Capture Video Screen
