29-08-2007, 08:13 PM
M$™ Certified Spammer
guys reall important help
whenever i run task manager it says task maager has been disabled by administrator
im not able to acces control panel and add or remove
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
29-08-2007, 08:27 PM
Dreamweaver
Re: guys reall important help
^ if you haven't done any changes then it might be a virus
The Devil's Advocate
its me  or a friend of mine
http://beingmanan.com
29-08-2007, 08:29 PM
Your computer is infected... Anyway do this:
Click Start, Run and type this command exactly as given below: (better - Copy and paste)
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Pol icies\System /v DisableTaskMgr /t REG_DWORD
You should be able to access task manager now...  And run a full system scan...
C2D E4300, MSI P6N SLI Platinum, Transcend 2GB 667MHz, XFX 8600GT, Viewsonic VG1930wm, Seagate 250GB SATAII, Lite-On LH-20A1P, Compro VideoMate X50, Microsoft wireless KB and Mouse, iBall Grabit.....
29-08-2007, 08:30 PM
Dreamweaver
^ hmm. . . you are just a virus, who can spread more from IM. and you have very low level threats. so probably some powerful than you
29-08-2007, 08:31 PM
it cud buy avast aint find nothing i managed to get back everything but i still think the virus is alive
P.S. There is no gap in the word 'Policies'...I dont know why its coming... Make sure u remove the spacing....
29-08-2007, 08:32 PM
Dreamweaver
^ thats for iMav
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
29-08-2007, 08:36 PM
Rest assured the virus or whatever will still be there... By the way can u run 'regedit'?? Also check whether u have 'Folder Options' under Tools in the explorer...
29-08-2007, 08:37 PM
dude i already enabled task manager by a lil googling
just thing the virus is stil there
29-08-2007, 08:39 PM
It is still there...
29-08-2007, 09:05 PM
well im not sure if the virus is still there or not buy the results of virus scan etc came clean so i think it was just reverted or something nontheless it doesnt matter i can use everything now at least so thanks anyways guys
29-08-2007, 09:54 PM
in search of myself
Guys do t worry about iMav
Moved to quarantine
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
30-08-2007, 02:44 PM
problem fixed- mods shutdown thread
30-08-2007, 02:58 PM
thats nice!
