Old 27-08-2007, 05:09 PM   #1 (permalink)
napster007's Avatar
Default torrent client problem
hey guys,
i have a problem. i was downloading a file using utorrent client. But now recently i was facing problems due to problem of port forwarding. Now i want to use another torrent client and continue downloading from 20%. plz tell me a way how to do it. and also suggest a good client
napster007 is offline
Old 27-08-2007, 05:14 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: torrent client problem
While saving the torrent file in the new client (I suggest the only other good alternative - Azureus, but it's heavy) give the location where the partial file exists. If you do that correctly the client will scan the existing data and start with the same percentage or 2-5% less than the completed one
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-08-2007, 05:15 PM   #3 (permalink)
Try bitlord
In utorrent save the torrent to ur hdd, then in bitlord preferences set the same path where Utorrent was saving the file & after that open the torrent u saved in bitlord that should resume from 20% onwards.
I have not tried this but knowing how these clients work I am suggesting this.
ranjan2001 is offline
Old 27-08-2007, 07:04 PM   #4 (permalink)
napster007's Avatar
hey ranjan2001,
i tried using bitlord but it din't work. it forms another folder in the specofied directory and starts downloading. i'll try azureus
Old 27-08-2007, 07:10 PM   #5 (permalink)
Commander in Chief
Then specify the folder right outside of the folder you just specified.
Harsh J
www.harshj.com
Old 27-08-2007, 07:20 PM   #6 (permalink)
left this forum longback
praka123's Avatar
Azureus "works".Is Azureus that heavy?for that matter even transmission can be used
praka123 is offline
Which is the BEST torrent client? aryayush Software Q&A 18 31-10-2007 11:37 AM
best P2P torrent client?? anarchy0x Software Q&A 3 03-01-2007 03:08 PM
Which is the best Torrent client? bharat_r QnA (read only) 99 26-07-2006 02:02 PM
bit torrent client problem. thegame_rulez QnA (read only) 7 14-04-2005 08:34 AM
- by chris
