Originally Posted by qadirahmed
then tell me the minimum requirement for 64bit
you have asked whether it would suite u or not...
it will suite me........?
im using celeron 2.53, on board video, 256 ram....
There I said, no... as if you have a 64bit processors you can run Windows x64 but it doesnt worth it...
read more... on those given links,
http://www.chotocheeta.com/2007/08/2...8-x64-editions
There is nothing new as from Vidual point a view in Windows x64
read more. on the given link...
Windows XP x64 would run under 256mb ram, its just the processor you have to make sure has 64bit support,
http://www.intel.com/products/proces.../celeron_d.htm there are few models of Celeron processors which all runs at 2.53 GHz so what us ur processors model number ??
