Old 25-08-2007, 04:50 PM   #1 (permalink)
Manchester United
abhijit_reddevil's Avatar
Red face Allow incoming connections to my computer from utorrent/azarues
Hi,
Pardon me if I am asking this question again. But I found no thread which discusses my specific problem. All threads discuss about hardware routers and how to port forward to them. Mods can lock this thread if this has been discussed before.
Recently I installed the latest version of Azarues/Utorrent. However the NAT test on the port that is configured in my PC as open shows no incoming connection message. Utorrent shows me a red exclamation mark and Azarues a red icon at the bottom of the program window indicating no incoming connections. I am using Zone Alarm pro and Win XP SP2. I added the two programs manually to the exceptions list in Zonealarm and also configured the port number in the expert rules page of the program control. But nothing seems to work. I am getting the same problem and low speeds in torrents.
I am using internet connection via cable through alliance broadband.
Please suggest where I went wrong and give me the correct procedure to allow incoming peer connections. Thanks! I followed the procedure mentioned in the following page:
http://www.bleepingcomputer.com/tuto...torial128.html
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 25-08-2007, 06:57 PM   #2 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Re: Allow incoming connections to my computer from utorrent/azarues
Hmm, i also use azureus u cud try game mode in zone alarm and put on answer all alerts on allow, u can try to change a port, or maybe te port ur using is blocked best way is trying to change the port
for azureus
tools > nat/firewall test
change the number there and click test hope it solves yer problem
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 26-08-2007, 03:13 AM   #3 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
which modem u r using then i tell u
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 26-08-2007, 09:45 AM   #4 (permalink)
Manchester United
I already mentioned that I am using internet through cable from Alliance Broadband. There is no DSL router, only the LAN cable.
Old 26-08-2007, 09:56 AM   #5 (permalink)
left this forum longback
praka123's Avatar
try random port no like 49174 and see.for me,i use Azureus on Debian/Ubuntu Linux firewalled allowing some random ports to be open.and it works!NAT test is OK!
praka123 is offline
Old 26-08-2007, 02:17 PM   #6 (permalink)
a.k.a Niks
Sylar's Avatar
1> try using a port above 50000 and try again...
2> if ur using zone alarm as ur firewall make sure u've put off xp firewall.. the 2 conflict like hell...
3> u can't do much really coz the router is not at ur location else u could have opened the port or port forwarded.. ask ur isp if he can do that for u if the above steps don't wrk but i doubt he will..
.. E6750 2.66GHz|Asus P5W DH D'lux|2x1GB Kingston 667MHz|XFX 6800GS 512MB OC|Seagate 7200.10 320+250+250GB|Sony DRU-830A|Coolermaster 600W|Creative 5.1 T6060|Logitech EX111+G5|ASUS VW192T|Antec 900 ..
Sylar is offline
Barring Incoming Calls. Massacre Mobiles and Tablets 9 13-03-2008 07:53 PM
How to disconnect unwanted incoming call automatically? Tech.Masti Mobiles and Tablets 12 27-04-2007 09:43 AM
BSNL dataone....incoming call alert!!!!!!! vijay_v Broadband and DTH 23 26-07-2005 07:12 PM
incoming mail in outlook express mahendran Software Q&A 1 06-11-2004 12:02 PM
- by chris
