25-08-2007, 03:46 PM
youtube problem
Hi folks,
We get to see so many videos on youtube. However, they dont allow us to save them. Previously I could do it by getting the files in the temporary folder, but lately they have become smart and it does not land there. Does anybody know how to save the videos that we watch on youtube. If so, please help me out. thanks a ton
lovemeall26
KNOWLEDGE SHARED IS ALWAYS FRUITFUL AS IT CAN BENEFIT YOU TOO ONE DAY. SO HEY GUYS LETS MAKE THIS A GREAT COMMUNITY TO SHARE IDEAS AND STUFF LIKE THAT,
CHEERS,
LOVEMEALL26
26-08-2007, 12:28 AM
I am Optimus Prime
Re: youtube problem
Go to www.downloadvideos.in and paste video url there and download!
26-08-2007, 12:43 AM
D i s t i n c t l y Ahead
Re: youtube problem
Originally Posted by lovemeall26
Hi folks,
lovemeall26
u can also use youtubegrabber nd vdownloader for this purpose also
plz use the search option before posting and ask ur Q in QnA section
27-08-2007, 01:28 PM
Cool as a CUCUMBAR ! ! !
Re: youtube problem
http://keepvid.com/ ..........
u can use ur download manager 2 ..........
... W H O T ...
27-08-2007, 01:40 PM
Re: youtube problem
http://www.keepv.com/
faster .. than keepvid
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
28-08-2007, 12:55 PM
Re: youtube problem
Yeah I also used to save from temp folder. Any idea where they save the temp file now ?
P4 2.4 GHz Prescott;768 MB RAM;Seagate 80 GB PATA & 160 GB SATA;Creative Inspire 5200;ViewSonic E71f;256 MB Leadtek A6600TD;Logitech MX518;Microsoft Natural Ergonomic 4000
28-08-2007, 01:50 PM
mera kutch nahi ho sakta
Re: youtube problem
^they are in the same folder, but with a different extension.
Earlier they were saved as somefile.flv, now they are saved as somefile.tmp.
Just sort files by 'size' in windows explorer, and simply grab the largest files.
where files land in your pc solely depends upon the browser and not any websitew
jin files ka koi server nahi hota unka bittorrent hota hai
Reason: Automerged Doublepost
28-08-2007, 01:52 PM
left this forum longback
Re: youtube problem
In Linux,u can find in /tmp folder these flash files.all are in the form "Flash^^*" without any extension.so do search ur win temp folder for ur browser for the same.
28-08-2007, 02:19 PM
Be CoOl rAp RuLeZ !!!
Re: youtube problem
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
28-08-2007, 02:22 PM
Re: youtube problem
if u use FF den u can use Ook? Video Ook! 0.6.6 it will save d flash file using d exact file name as it appears on d youtube site
if u wan 2 use a download manager then u may paste in d url in Youtubex
but all file will be saved as getvideo
i doubt it will work, 'cause d max filesizes i've been getting in my Temporary Internet files folder is around 80-90KB 4 iles of 3-4 min length even after d whole vdo has been streamed
i think dey r splitting d stream in lotsa tmp files 'cause dats wat i get wen i stream d vdo
28-08-2007, 03:22 PM
in search of myself
Re: youtube problem
If you are using Firefox you can also use Unplug Extension for it
https://addons.mozilla.org/en-US/firefox/addon/2254
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
28-08-2007, 04:09 PM
Re: youtube problem
hmm, post the URL. I'll see f I get a similar result
Also it just might be a good idea not to use IE
28-08-2007, 05:59 PM
Re: youtube problem
ok this file i actually chose @ random
http://youtube.com/watch?v=xGlZbNJP--c
d max file size dat i got we playing dis file was 41 KB
dat 2 a CSS document
pathe wer i cheked out
C:\Documents and Settings\uSER_NAME\Local Settings\Temporary Internet Files
actually now wen 1 saw i found dat der r no *.tmp files
just
*.43 *.css *.htm *.gif *.jpg *.png *.txt *. js
1 xml document
and 3 three files with no extension
28-08-2007, 06:07 PM
Re: youtube problem
jfyi,in Linux we can get the files in /tmp folder as easy.then how can it works if the logic that files are splitted
02-09-2007, 04:51 PM
Re: youtube problem
Hello Novjotsingh,
Thanks for giving the link of www.downloadvideos.in coz it did work for some time as I managed to download and save the files too on my comp. But lately, it seems you tube read your suggestion and have rectifiied that flaw of theirs too. Because now when I put the url in the above mentioned website, it does allow me to save but in MS DOS format and not as a .flv file. Hence, an executable file ends up being saved on my comp which when opened results in nothing.
Also another suggestion to save the largest file in the temp folder also does not work coz the actual file seems to be dismembered and saved in different formats in the temp folder which does not make it possible to save the actual whole file. So any other suggestions to help solve this problem.
Thanks in advance to all the techies once again. looking forward to hearing from you guys soon.
lovemelal26
CHEERS,
LOVEMEALL26
02-09-2007, 11:38 PM
Cool and Calm
Re: youtube problem
hmm...can use youtube grabber too
When Roger's at play, opponents pray..!!!!! :twisted:
