25-08-2007, 01:49 PM
Searching...
Help against VIRUS !!
Guys please help me. My system had got infected by a virus few days ago. I don rememeber the name now sorry. I have Kaspersky installed which is up-to-date. So I scanned my PC thoroughly and many files were corrupted, I deleted all of them. But yesterday when I tried to use the my Folder options it was no longer opening !!! I re-scanned my PC but no virus found !! What should I do now.. ? Is there any way to restore it ?
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
25-08-2007, 03:11 PM
dá ûnrêäl Kiñg
Re: Help against VIRUS !!
Refer this thread of vishal gupta were there is a registery entry given to restore back folder option
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
My Stomach pains:D:D
http://tinyurl.com/32jj4m
25-08-2007, 03:23 PM
guys im unable to find d NoFolderOptions DWORDvalue
i have a fully functioning Folder Options window
i still wanted 2 have a look @ it
so d path ver i luked 4 was
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\Explorer
i'm runnin Win Server 2003 Web Ed
ver id my NoFolderOptions DWORD value
25-08-2007, 05:14 PM
Searching...
Thx man. That vishal gupta thread helped me totally... I had forgotten his thread.. VISHAL you ROCK MAN !!!
26-08-2007, 09:06 PM
dig_boy_dig,dig !
Guys today my system is infected by a virus name "PE_RESOURCER.A"
I scan my system with Trend Micro's SysScan and it detect five file as infected. Now How can I clean these file.
C:\WINDOWS\SYSTEM32\igfxtray.exe [PE_RESOURCER.A]
C:\WINDOWS\SYSTEM32\hkcmd.exe [PE_RESOURCER.A]
C:\Program Files\Alwil Software\Avast4\ashDisp.exe [PE_RESOURCER.A]
C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe [PE_RESOURCER.A]
C:\Program Files\Hewlett-Packard\HP Share-to-Web\hpgs2wnd.exe [PE_RESOURCER.A]
47466 files have been read.
47466 files have been checked.
43173 files have been scanned.
74497 files have been scanned. (including files in archived)
5 files containing viruses.
Found 5 viruses totally.
Maybe 0 viruses totally.
________________________________________________
I like signature after 10 P.M.
27-08-2007, 08:54 PM
Hey guys!!!
can anybody give me a suitable answers to the query i posted up
still waiting.............
27-08-2007, 09:24 PM
I am Optimus Prime
If its not there then create one yourself. It should work that way too.
27-08-2007, 10:37 PM
the problem/question is not about creating it
d fact dat i have a fully functional Folder Option window, means that there is a registry entry that is making Folder Option accessible
all i want 2 know is that where is that entry if it is not in the loaction i specidied
28-08-2007, 04:43 PM
Searching...
do you have more than one acc..? If yes then in that case my be your other account's folder options is not working and you might be checking that one.. !! If you have confirmed this then sorry for doubting you !!
28-08-2007, 05:47 PM
i got only 1 account Administrator account
30-08-2007, 01:58 AM
Microsoft MVP
Not all things are handled by registry. So u'll never find the key to show Folder Options in Registry Editor.
"NoFolderOptions" DWORD value is used to disable Folder Options. Its not like you make "ShowFolderOptions" and it'll start showing it. These DWORD values are predefined in Windows. Actually such DWORD values were created to restrict users for sharing environments. So there is no as such DWORD value.
30-08-2007, 02:04 AM
so if i want to disable the Folder options window
how will i do it?
do i create a new dword value and give it a vlue of 1
as for sharing environments do you mean multiple user login names?
30-08-2007, 02:18 AM
Microsoft MVP
^^ Yep. No such DWORD value is pre-made there. You hv to make one and set its value to 1.
30-08-2007, 10:15 AM
Thanks buddy
This thingy had been troubling me for some time.
Now I can rest easy.
30-08-2007, 01:49 PM
Microsoft MVP
^^ Welcome.
