Old 22-08-2007, 10:16 PM   #1 (permalink)
damn busy...
utsav's Avatar
Unhappy xp reinstallation problems.someone plz help
I am unable to reinstall xp over my existing installation.i am starting the installation from xp itself ,it copies all the files and restarts the pc but when the installation commences it gives an error that a file is missing.
what to do
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 23-08-2007, 02:36 AM   #2 (permalink)
Default Re: xp reinstallation problems.someone plz help
Please explain in full. You said that you started installation from XP itself that means you are offline upgrading (Repairing). Is that it. If so or even you are fresh installing XP, I think that the cd you are using for installation have some files missing or corrupted. Try using some other disk.
abhipal is offline
Old 23-08-2007, 07:58 AM   #3 (permalink)
CD must have a problem , use another XP CD if u have a backup. or worst case that ur HDD may have a bad sector which is causing the problem.
ranjan2001 is offline
Old 23-08-2007, 01:58 PM   #4 (permalink)
damn busy...
utsav's Avatar
@abhipal. i am starting the reinstallation from windows xp by clicking on the upgrade tab so that my current settings remain intact .
@ranjan2001. my hard disk doesn't hav any bad sector
www.techjunkiez.com
utsav is offline
Old 23-08-2007, 02:12 PM   #5 (permalink)
problem is either with your cd or ram.
casual_gamer is offline
Old 23-08-2007, 02:13 PM   #6 (permalink)
IN past my experience upgrading XP has not been gud, I would take a back up of data & reinstall rather than lingering with problem after successful upgrades.
Old 23-08-2007, 02:57 PM   #7 (permalink)
damn busy...
utsav's Avatar
so why during copying the files no error comes and memtest doesn't shows any problm in ram
www.techjunkiez.com
utsav is offline
Old 23-08-2007, 03:02 PM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
This can happen, as when you are coping a file u copy the archive, but when running the installation you extract and expand the setup archive files, so its possible that the Installation media do have problem or your Optical drive is unable to read from the Media...
I would suggest, use another installation media if posible... (Note if you have a Windows OEM key, then use any OEM installation Source with ur own key)....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 24-08-2007, 02:00 PM   #9 (permalink)
Try Windiag, it is very accurate to test RAM. http://oca.microsoft.com/en/windiag.asp I once had a similar problem, the problem was with one of the ram sticks, fortunately there was still 1 month warranty left and i got it replaced.
Old 24-08-2007, 03:09 PM   #10 (permalink)
damn busy...
utsav's Avatar
^^ok, i will check it
should i copy all the files on my cd to hard disk and then install xp.will it work
www.techjunkiez.com
utsav is offline
XP reinstallation problem Suhas Software Q&A 7 24-08-2007 01:30 PM
IE 6.0 Corrupted, reinstallation also doesn't helps. Mangal Pandey Software Q&A 9 26-02-2007 08:58 PM
Webroot's SpySweeper reinstallation problems rakesh-the gilli Software Q&A 4 27-07-2006 09:34 AM
Recovering GRUB after reinstallation of windows kadal27 Software Q&A 2 14-08-2005 01:58 PM
- by chris
