Old 21-08-2007, 08:52 PM   #1 (permalink)
Exclamation Problem with NERO
I hav installed Nero ver7.2.2.4 which came with my Lite-on DVD drive.
I am facing a problem when i try to burn a MP3 DVD.
when i add some(not all MP3's) i get some message like
"one or more files cannot be added to compilation
It may be possible, that the files can be added, if a dedicated plug-in is installed"
Now i hav referred to the Nero site and saw that by clean install of Nero using Nero 7 clean install it would eliminate such problems but it didnot in my case plz help..
I'm attaching the cap of wat i exactly get ...
Hari_04415 is offline
Old 21-08-2007, 10:41 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: Problem with NERO
Look for an MP4 or AAC plug-in for Nero.
Try the FAAC AAC/MP4 v1.0.0.33 plugin
http://www.bitburners.com/Software/D...Audio_Plugins/
Can't you burn a CD with Itunes?
debsuvra is offline
Old 22-08-2007, 12:43 AM   #3 (permalink)
Still learning...
He28's Avatar
Nero su*ks. It is a piece of cr*p. I wasted many CDs and DVDs because of Nero.
Dump it and Google for some other CD-DVD burning software.
People laugh at me because I am different...,
I laugh at them because they all are the same...
This is... attitude!
He28 is offline
Old 22-08-2007, 04:41 AM   #4 (permalink)
I Always Prefer 1080p
techtronic's Avatar
I completely disagree. I have been using Nero from v5 and now I am currently using v7. I have not lost even a single CD/DVD because of Nero.Often people complain about burning software but hardly one may feel that the problem might be even due to the media or drive itself
techtronic is offline
Old 22-08-2007, 09:12 PM   #5 (permalink)
i hav shifted frm nero7 to nero v6.6 and this has solved my problem
nero showtime 3 and nero 7.7.5.1 problem Shasta Software Q&A 17 22-02-2007 02:37 PM
Nero 7.5 Problem vivekrm007 Software Q&A 10 23-01-2007 07:26 PM
NERO Problem rajkumar_personal Software Q&A 15 04-03-2005 05:08 AM
PROBLEM WITH NERO liquid_nitrogen88 Software Q&A 4 11-12-2004 01:50 AM
Nero 6 & problem with writing photo cds with nero sarincv Software Q&A 1 09-11-2004 08:22 PM
- by chris
