Old 21-08-2007, 02:36 PM   #1 (permalink)
Default XP reinstallation problem
I had to reinstall XP, but unluckily there was a power outage and I had to shut it down in the middle.When I tried later, it gave a message that 'setup is being restarted...' and then there was blank screen (with the mouse) and the reinstallation did not proceed.I had to make a clean install of XP on another drive.Is it possible to recover my old XP, since I have to install so many apps on the new XP and it is very frustrating and time-consuming task ? My old XP is installed in C: and I cant boot into old XP.
Suhas is offline
Old 21-08-2007, 06:09 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: XP reinstallation problem
and then
These 2 statements are contadictory... !! as far as I see your Old XP is not yet been installed then how can u expected to boot back in ??
I would suggest just do the Re-Installation Process once again from Start, meaning boot with Windows XP installation disk then re-install !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 21-08-2007, 11:40 PM   #3 (permalink)
The Frozen Nova
casanova's Avatar
You should have reinstalled it in the same drive.
BTW, the blank screen you were saying comes because of driver loading. It takes around 10 mins for it to disappear.
I faced this problem a hell lots of time on my old celeron computer.
www.nerdweed.blogspot.com
casanova is offline
Old 22-08-2007, 03:31 AM   #4 (permalink)
I m currently having a similar problem, was actually upgrading my XP SP2, but had to shut down in the middle because of power failure
Nxt it boots fine ....but all my drivers are gone....that includes audio Realtek AC'97, printer, modem and infrared drivers.
I reinstalled them but m having a serious prob with the audio driver....now whenever i play a song it never plays smoothly....meaning there are abrupt breaks and music stretches with the slightest increase in CPU usage, which is really irritating.
I tried reinstalling the realtek driver ver:A4.00 and Ver:R1.71 but to no avail.....plz help.
neet_online is offline
Old 22-08-2007, 09:48 AM   #5 (permalink)
The Frozen Nova
casanova's Avatar
First unistall both audio drivers and graphics driver.
Restart the Pc
Install graphics driver
restart
Install audio driver
This should work.
casanova is offline
Old 23-08-2007, 01:52 AM   #6 (permalink)
thanx
Cud you gimme the links or from wher i shud d/l my graphics and sound drivers??
Is ther some prob with realtek drivers.....if no then which version shud i go for??
mine is 2.0 Ghz 256mb ram with no additional sound card.
Old 24-08-2007, 01:24 PM   #7 (permalink)
I did try from first.....I put XP CD, then started PC, and then I repaired it...but then again I got the same blank screen after it aitomatically reboots.
Suhas is offline
Old 24-08-2007, 01:30 PM   #8 (permalink)
Rebooting
Get in to recovery consol and run one command to check ur HDD for bad sector...
run command chkdsk
also if you have another free partition then try installing one fresh copy there... you may have problem with ur RAM or HDD.... Therefore if possible just open up the cabinet and try cleaning the RAM and their slots....
rebooting
ChotoCheeta.com
IE 6.0 Corrupted, reinstallation also doesn't helps. Mangal Pandey Software Q&A 9 26-02-2007 08:58 PM
Format C drive without losing Windows! (no reinstallation of Windows or anything) agent007bond Software Q&A 23 27-09-2006 01:20 AM
Webroot's SpySweeper reinstallation problems rakesh-the gilli Software Q&A 4 27-07-2006 09:34 AM
Recovering GRUB after reinstallation of windows kadal27 Software Q&A 2 14-08-2005 01:58 PM
- by chris
