Old 21-08-2007, 11:01 AM   #1 (permalink)
digiFriend's Avatar
Question 2.0 G.B flash drive formated ,showing 128 M.B only
2.0 G.B flash drive formated and now showing only 128.M.B. window disk management is also showing only 128.M.B. (it is not showing any unallocated space in flash drive.)
paragon partition manager is able to format flash drive, but it also showing 128 M.B.
how to get back full storage space back.
you never know what you can do until you try
digiFriend is offline
Old 21-08-2007, 11:02 AM   #2 (permalink)
slugger's Avatar
Default Re: 2.0 G.B flash drive formated ,showing 128 M.B only
did u by any chance buy it from china
u've been ripped by ur dealer
and btw dis tiopic has been discussed many times on d forum
u shud have searched b4 postin
[not expected from a member whos got 200+ posts ]
slugger is offline
Old 21-08-2007, 11:37 AM   #3 (permalink)
digiFriend's Avatar
i have been using full 2.0 G.B for quite long time. i mesh it up because i wanted to make it bootable.
before posting i have searched, and it have shown many many thread. all showing useless result. even advance search does not help. it shows lots and lots of off topic thread.
Old 21-08-2007, 11:49 AM   #4 (permalink)
slugger's Avatar
first page results
RESULT 1
RESULT 2
if im not wrong dis was d first time u formatted d disk
slugger is offline
Old 21-08-2007, 12:30 PM   #5 (permalink)
digiFriend's Avatar
thanks slugger for instant reply and help.
i have read this thread before posting. they are all related to cheap chinese version.
i have Scandisk brand with bill and warranty.
i have got the solution and its is showing its 2.0 G.B again full capacity.
i have used Active@ killdisk software. and its Zero filling utilities has solved the problem.
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
Disable Showing Drive Letters Panchu Software Q&A 1 01-08-2006 12:09 AM
help C:/ drive is showing very little empty space! apurvrdx Software Q&A 4 26-01-2006 08:05 PM
Flash file of website not showing in browsers!! plz help** kool Software Q&A 5 09-07-2005 11:54 PM
- by chris
