Old 20-08-2007, 12:16 PM   #1 (permalink)
nik_for_you's Avatar
Default vista problem
hi,
I am using vista home basic edition since 1 month..
since some times i m finding problem in driver istallation..
problem is when ever i insert any plug and play device even pen drive. first it serches for driver and then prompts me to give location of driver !! it is not able to install driver automatically.. even drivers for disk drives, mouse are not located automatically..
have i modified any setting or what?
please help
I AM REBEL
nik_for_you is offline
Old 20-08-2007, 02:58 PM   #2 (permalink)
slugger's Avatar
Default Re: vista problem
Originally Posted by nik_for_you
hi,
r u sayin dat wen i first installed Win Vista u did not face dis problem?
actually d problem dat u mentioned arises bcos vista does not seem 2have ne vista-compatible drivers 4 ur hw in its db
dat is y it is askin u 2 provide it wt vista-comaptible drivers
u may want 2 check ur hw offcial website 2 c wat drivers dey came up wit 4 vista and install dem b4 plugging d hw back in
slugger is offline
Old 20-08-2007, 03:47 PM   #3 (permalink)
ya i think for first 15 days i was working..
when i tried to do partition in hdd then also it asked me to give path for "disk drive" driver..
i think drivers for disks should be by default in vista..
and when i manually locate path for the driver, it searches the driver and installs.
but this should be done automatically just as xp ..
I AM REBEL
Old 20-08-2007, 03:57 PM   #4 (permalink)
slugger's Avatar
in an ideal world Vista shud have installed it automatically
but Vista is still quite new, so its db of hw drivers is still not vast enuf 4 all d hws dat people use
whereas XP is almost 5 yrs old now so it has had enuf time 2 come up with d drivrs comaptible with a lot more hws by now
slugger is offline
Old 21-08-2007, 08:23 AM   #5 (permalink)
may be..
but vista is preconfigured in laptop. so it should have its own hdd's driver !!
whatever..
anyone can suggest me more
I AM REBEL
Old 22-08-2007, 04:37 PM   #6 (permalink)
no one to help here
I AM REBEL
Vista Problem destiny4yash Software Q&A 3 23-07-2007 09:44 AM
Vista problem maverik99 Software Q&A 8 19-03-2007 06:11 PM
Vista Problem Or Hardware Problem ? Jayanth.M.P Hardware Q&A 7 12-02-2007 02:04 AM
Vista problem Anindya Software Q&A 3 06-10-2006 10:37 PM
Vista problem tanush_89 Software Q&A 2 09-08-2006 02:03 AM
- by chris
