| Forum |
#1 (permalink) |
I have: PIII 1.13 Ghz, windows 98(c 40 GB HDD(10GB/partition), I am having following BUNCH of problems sience last few months *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*- 1) sometimes windows XP, while starting, shows Blue Screen with "STOP:0xhhhhhhhh" message, where "hhhhhhhh" is a hex code. Till now I have got these messages: -----------------ERROR MESSAGE--------------------------------------- STOP:c000021a{Fatal System Error} The session manager initialization system process terminated unexpectedly with a status of 0xc000026c (0x00000000 0x00000000) The system has been shutdown. -------------------------------------------------------- -----------------ERROR MESSAGE--------------------------------------- STOP:c000021a{Fatal System Error} The windows logon process system process terminated unexpectedly with a status of 0xc000007b (0x00000000 0x00000000) The system has been shutdown. -------------------------------------------------------- Also, once I got a dialog box with following message: -----------------ERROR MESSAGE--------------------------------------- The application or dll F:\windows\system32\msgina.dll is not a valid windows image. Please check this against your installation diskette. -------------------------------------------------------- After clicking "OK" I got a message box, with a button to restart, informing about failure of windows GUI initialization. *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*- 2) The above kind of Blue screens were also displayed while PC was running normally. -----------------ERROR MESSAGE--------------------------------------- STOP:0x0000008E(0xc0000005, 0xBF845A45, 0xF0D804A0, 0x00000000) Win32k.sys-address BF845A45 base at BF800000 DateStamp 41107F7A -------------------------------------------------------- *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*- 3) The visual settings changes to classic windows looks. Even if I re-adjust the looks to winXP (use visual styles)from MyComputer Properties it doesn't sometimes, in such case the Appearance tab in Display Properties lists only "Windows Classic Style" and not "Windows XP Style". *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*- 3) The CDs and DVDs don't auto play in WinXP, but auto plays normally in Win98. I have not disabled autoplay feature, It happened just like "next day it's not working". I have Liteon DVD writer and Sony CD writer. *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*- 4) I access sancharnet using 56kbps D-link modem. Sometimes even after connecting to Internet I can't browse and get 404 error everytime. On running ipconfig/all, in this situation, the o/p is of following kind: ----------------------------------------------------------------- PPP adapter SancharNet: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface Physical Address. . . . . . . . . : 00-53-45-00-00-00 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 0.0.0.0 Subnet Mask . . . . . . . . . . . : 0.0.0.0 Default Gateway . . . . . . . . . : 61.1.100.233 NetBIOS over Tcpip. . . . . . . . : Disabled PPP adapter SancharNet: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface Physical Address. . . . . . . . . : 00-53-45-00-00-00 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 61.1.100.233 Subnet Mask . . . . . . . . . . . : 255.255.255.255 Default Gateway . . . . . . . . . : 61.1.100.233 DNS Servers . . . . . . . . . . . : 61.1.96.65 61.1.128.5 NetBIOS over Tcpip. . . . . . . . : Disabled ------------------------------------------------------------ When it connects normally the o/p for ipconfig/all is of following kind: ------------------------------------------------------------ PPP adapter SancharNet: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface Physical Address. . . . . . . . . : 00-53-45-00-00-00 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 61.1.101.170 Subnet Mask . . . . . . . . . . . : 255.255.255.255 Default Gateway . . . . . . . . . : 61.1.101.170 DNS Servers . . . . . . . . . . . : 218.248.240.208 218.248.240.135 NetBIOS over Tcpip. . . . . . . . : Disabled ------------------------------------------------------------ I'll be really thankful to u for the help in gettting around the problem. Thanks in advance, Lalit |
#2 (permalink) | |
The Thread Killer >:)
For 0xc000026c error messageRefer this link
For 0xc000007b error messagethis link For the msgina.dll file problemReferthis link The registry must have gone kaput making the "autorun" go bad.So save the following as a *.reg file and double click it, once saved. Quote:
Hope the links work out fine for you.
Want to make this world a better place? Then, start seeding and don't be just a leecher |
#3 (permalink) |
Is actually a real word..
yeah sounds like your HDD has just about had enough...virus/malware problem most likely, post hijackthis log here.
“They put me here because I’m from Canada and they think I’m slow, eh?..." |
#4 (permalink) |
Booting Nicotine!!
and also tell us if ur using fat or Ntfs
http://spironox.blogspot.com Rig : Asus P4 p 800SE ( happy ) Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Window display fatal Error during startUp | Kaushal Hiwarkar | Software Q&A | 2 | 13-05-2007 12:23 PM |
| windows 'stop' error | purujitb | Software Q&A | 27 | 20-02-2007 11:00 AM |
| Firefox: Fatal error in videodownloader plugin | Rollercoaster | Software Q&A | 10 | 22-08-2006 06:37 PM |
| win xp installation stop error pfn_list_corrupt 0x0000004e | patelsunilp | Software Q&A | 3 | 15-04-2005 12:05 AM |
