Old 17-08-2007, 09:54 PM   #1 (permalink)
Default Problem in installing CS3 suite
I am unable to install the adobe creative CS3 suite(from digit dvd) on my laptop running Windows Vista.I even downloaded photoshop CS3 from adobe's site and couldn't install it.The setup file starts with a small dialog which disappears after 5-6 seconds.The file is not corrupt as I could install it on another computer.I earlier had photoshop CS3 beta installed which didn't uninstall properly so I manually deleted it.
Please tell me how can I install it.
Areeb Khan is offline
Old 18-08-2007, 01:22 AM   #2 (permalink)
slugger's Avatar
Default Re: Problem in installing CS3 suite
u did wat??
it is probably d reason y ur CS3 trial not getting installed 'cause der is still all d registry entries pointin 2 presenc of CS3 beta on ur comp
AFAIK u r allowed 2 install only 1 instance of d sw on d comp @ a given time
so ne attempt 2 install trial will b prvented bcos of d old beta registry entries
if u want 2 c wat error message popped up go 2 Event manager and c d appropriate entry
[judging by ur axn, i can bet my money on d fact dat u will have an extremely messy event viewer wen u open it]
slugger is offline
Old 18-08-2007, 12:40 PM   #3 (permalink)
I deleted all the registries named photoshop.
The log file of the setup states internal error 2739.
Old 18-08-2007, 12:43 PM   #4 (permalink)
slugger's Avatar
ok den it refers 2 unregistered java script dll file
use d command pompt 2 re-register d jscript.dll file
slugger is offline
Old 18-08-2007, 01:11 PM   #5 (permalink)
Please tell me how to do that.
Old 18-08-2007, 02:14 PM   #6 (permalink)
slugger's Avatar
type dis in2 command prompt
regsvr32 jscript.dll
take care 2 mantain space between d 2
if it stil gives u problem den do
regsvr32 /u
slugger is offline
Old 18-08-2007, 05:09 PM   #7 (permalink)
Thanks!!
It worked.
should i remove zone alarm security suite if i install kaspersky internet suite??? tango_cash Software Q&A 4 01-08-2007 02:20 AM
Nokia PC Suite Problem !!!! dreams Software Q&A 5 17-07-2007 10:10 AM
Error message after installing SE PC Suite janitha Software Q&A 2 09-05-2007 09:31 PM
Problem with PC Suite connectivity.. kumars Software Q&A 3 10-11-2006 12:21 PM
Problem with PC Suite esh1manarsenal Software Q&A 15 14-08-2006 11:02 PM
