Old 17-08-2007, 10:17 AM   #1 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Booting And Sound Problem
From past few days i cant hear anything from my creative 5.1 speakers..
I dont usually hear music on my PC...but one day i wanted to but i couldnt....
I have Creative 5.1 Soundbalster live sound card......with the s/w provided with it i have tested it and it has passed all test...so no problem with sound card or speakers.....just problem is i cant hear anythiing....
I also have problem booting ...PC usually hangs at BOOTUP windows screen....
After many startups its boots properly..or i have to go to SAFE mode and and then boot agian..and then it boots properly....
In between such activity ....my sound was BACK.....but after working for few minutes..PC hung and i had to restart my PC....and agian same problem... ...so agian no sound......
I have reinstalled DRIVERS for soudn card...updated them...reinstalled XP (upgrade option) but it has not helped......
Also i will like to knwo any regedit or s/w to uninstall DIRECT X....tried fewa available s/w on net but it didnt help..as i guess problem is with some dll file from directx
Members help with this ASAP..as my last option is FORMATTING THE PARTITIOn and re install WIN xp.....but i wanna knwo if any SOLUTION or SOFTWARE can help me.....
wizrulz is offline
Old 17-08-2007, 11:00 AM   #2 (permalink)
Default Re: Booting And Sound Problem
IF u already have though such mess then I would 1st advice to have a reformat & a clean install of XP.
Since this sound card is quite old (I too have this model) hope that u have the last updated driver.
ranjan2001 is offline
Old 17-08-2007, 01:16 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
yeah i know that...thats my LAST CARD .....but waiting for solution if any
wizrulz is offline
Old 18-08-2007, 02:19 PM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
helloo problems and mor eproblems
I have formated my drive and resintalled XP
Yet problem with SOUND..... .....first installing the drivers and now after i have installed drivers......no SOUND....no i do not have any option also....(
wizrulz is offline
Old 18-08-2007, 02:37 PM   #5 (permalink)
Seems driver issue, I checked my latest drivers list as follows.
creative Driver version 5.12.2.252 dated 24th july 2002. Do u have the latest drivers???
Try different pci slot on the mobo, just to rule out hardware problems.
Did u installed any microsoft update which may be causing this problem. Asa last resort try another XP cd for installation.
Old 18-08-2007, 03:57 PM   #6 (permalink)
Remove the drivers then shutdown and remove the card and insert in a different pci slot.
See if it works.
sashijoseph is offline
Old 18-08-2007, 06:36 PM   #7 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
I do not know how many times i have installed XP on my PC, checked my sound card and speakers...(but never removed my Soudn card as i knew there was no problem with speakers and sound card)......upgarded (w/o format) Windows XP......and tried all stuf...yet SOUND and booting ( yeah surprisingly even after fromat and reinstall ) it persisted...
so i removed one of my 512 mb ram and reinstalled Xp ( upgraded)...and ya SOUND WAS BACK.....while posting this i am hearing to songs.....and now suddely they have stopped ...will have to check out....i am afraid of rebooting as then after many reboots or upgrade only my PC starts.....i am in BIG mess......
wizrulz is offline
Old 18-08-2007, 06:43 PM   #8 (permalink)
1st of all dont reformat too often , we need to isolate the problem so we can locate if its hardware or the driver issue.
do u have any other XP cd to install from?
can u post screen shots of creative driver window?
Old 18-08-2007, 06:49 PM   #9 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
i have same driver version as urs...tell me ur DIRECTX version..as usually there is conflict between dll files of SOUDN card and DIRECT X.......
Right now suddenly while i was listening to songs teh SOUND has Gone
wizrulz is offline
Old 18-08-2007, 07:37 PM   #10 (permalink)
I have DirectX 9.0c
Old 18-08-2007, 08:26 PM   #11 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Ya but whats the nos ....version nos..i also have directX 9c but its has nos as
DIRECTX 9C (4.09.0000.0904)
wizrulz is offline
Old 18-08-2007, 08:46 PM   #12 (permalink)
Same as u have
DirectX 4.09.00.0904 (DirectX 9.0c)
Old 18-08-2007, 09:19 PM   #13 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Guys guys i am getting problem back....now one more question....
can this be due to overheating????????
wizrulz is offline
Old 18-08-2007, 10:29 PM   #14 (permalink)
I don't think so, ........overheating what............card itself or the cpu???
I have run this sound card in a small cabinet without any problem, there were no extra fans in the cabinet at that time.
1st of all download arconis true image & now when u make fresh install , insatll true image & make a clone of the partition so u can revert back again & again without reformating..then don't install creative drivers & test the sound card without the driver.....its should work & give u sound
I remember XP will ask for hardware driver but don't install it..........let the card run on its native support drivers & then see what happens..........this way we will get to know if the driver is having a problem or not.
You now got to follow steps carefully so we can find & isolate the cause......who knows the card itself may have developed a problem.......to rule taht out ask a friend if they can let u install the card in their PC & test it there.
What config r u running???
Old 19-08-2007, 03:46 AM   #15 (permalink)
Is actually a real word..
when u reinstalled windows did you install chipset... I remember seeing this problem on here before, let me search for it and I'll try and get back to ya, unless someone beats me to the punch
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Old 19-08-2007, 12:52 PM   #16 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
My config
AMD 3000+
MSI RS480
1gb + 512 Mb transcend ram ( now just 1 gb ..removed 512Mb)
No graphics card
Now from yesterday ...SOUDN is back.. ....crossed my fingers...but ya its weird.....suddenly all drivers accepted..as sometimes previously while isnatlling drivers ( for soudn card) PC used to hang...now after few RE- boots its working fine...but ya BOOTING is still problem...
Yesterday did
FIXBOOT...yet today while starting if i dont move my mouse it hangs...my PC is acting weird..a new problem crops up.....
Abt acronis..i have it....but will not clone drive take space...my Hdd is pretty ful ....does it compress ...or any other s/w which compresses clone image....and ya would had made clone image..if i was sure that everything is running fine...but till now not sure.....
wizrulz is offline
Old 19-08-2007, 02:25 PM   #17 (permalink)
Yes it compresses the backup image. Quite strange issues u r reporting.
Old 19-08-2007, 05:21 PM   #18 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
i am also surprised and ........
wizrulz is offline
Old 21-08-2007, 12:45 AM   #19 (permalink)
u reinstalled everytrhing from scratch or a disk image? I am assuming XP is on C dirve. how many partitions do u have and how much free HDD space do u have, how much virtual mem do u have. have you tried chkdsk /r or sfc /scannow?
Liggy is offline
Old 21-08-2007, 12:47 PM   #20 (permalink)
Booting Nicotine!!
spironox's Avatar
hmm try one thing this is the idiotic answer from my side ..but try for once
check the connectors ,
refix the processor,
clean the pci slot
ram check and
HDD check too .. that is the basic..
chances may be your soundcard blew !!
idotically-nixon
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
spironox is offline
Old 27-10-2007, 09:03 PM   #21 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
I am at it AGAIN .............
from past few days its agian giving me no SOUND...(
when i check option of digital ouput of my speakers its gives me HISS sound...that means my speakers and soudn card is working fine....
reinstalled drivers for SOUND CARD.....
I ahve also checked with CREATIVE one utility which checks for SOUND CARD h/w ......and its detecting everything........
yet NO SOUND (
wizrulz is offline
Problem booting XP opokharel Software Q&A 1 09-02-2007 12:45 AM
booting problem gau_pppu Hardware Q&A 2 23-11-2006 01:52 PM
booting problem amey kerkar Software Q&A 5 30-07-2006 03:36 PM
Booting Problem vineetrocks2005 Software Q&A 4 19-05-2006 11:05 AM
booting problem ranjan Open Source 3 07-05-2005 01:50 PM
