Old 17-08-2007, 09:04 AM   #1 (permalink)
Exclamation Problem with DAP
I am using windows XP with SP2 installed
Recently i hav installed DAP ver8.0
and when i open it it gives me an error message that
"Download accerlerator has encountered a serious problem and needs to close"
Plz help me
Hari_04415 is offline
Old 17-08-2007, 11:30 AM   #2 (permalink)
lalam's Avatar
Default Re: Problem with DAP
Don't use that software so maybe your set up file was corrupted in the first place or try un-installing and installing again and see if it helps
lalam is offline
Old 17-08-2007, 09:22 PM   #3 (permalink)
pushkaraj's Avatar
Are u using some other download manager like Internet Downlioad manager. If yes, then keep only one download manager installed on ur pc. Remove all other download managers otherwise they will always keep clashing with each other.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness
Think of your 3 best friends. If they are OK, then it's YOU
pushkaraj is offline
Old 19-08-2007, 11:23 AM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
re-installation will do the trick .........
... W H O T ...
ax3 is offline
Old 19-08-2007, 11:33 AM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
Off Topic, Some how I still Feel when Considering DAP the older 5.2 Version is still the best
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 19-08-2007, 09:17 PM   #6 (permalink)
re installation didn't work
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
