Old 16-08-2007, 07:44 PM   #1 (permalink)
free as a bird
Default help in saving passwords
Hi guys I use firefox, i want to re install windows xp, problem is i have a lot of bookmarks and password saved which i dont to write or remember . Is their a way that i can save my passwords on other drive .dont tell about using an extension for firefox which create profile of extension .the last time i use that exten i am not able to revive my password and extensions
vicky_l7 is offline
Old 13-09-2007, 05:30 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: help in saving passwords
I guess moving the password file would help?
It's an encrypted file located at:
C:/Documents and Settings/<UserName>/Application Data/Mozilla/Firefox/Profiles/<something>.default/signons.txt
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-09-2007, 06:11 PM   #3 (permalink)
din
Tribal Boy
din's Avatar
1. There is import / export password extension which work without any problems. Not sure which one you used.
2. As suggestd by QwertyManiac
3. You can always consider portable apps in future
Link
din is offline
OE passwords ! ! ! ax3 Software Q&A 7 13-10-2006 02:10 PM
LAN network passwords... prankzter Networking 1 09-03-2005 01:15 AM
passwords in win xp mahendran Software Q&A 1 08-12-2004 07:04 PM
- by chris
