| Forum |
#1 (permalink) |
"f:/ access is denied" but it opens wen i rite click it & select open.wht shud i do? dont suggest 2 format. plsss help |
#2 (permalink) |
NP : Crysis
a friend of mine had a similar prob which got rectified after a throrough virus scan and spyware scan. i suggest u use avg anti-virus and ad-aware anti spyware. both are free and very effective.
if a normal anti-virus scan comes up with nothing, try scanning ur sys when in safe mode
Gaming: Phenom II x4 965BE @ 3.6Ghz/Corsair H50 Liquid Cooling/MSI 790FX-GD70/2x2GB GSkill Ripjaws 7-7-7-24/3 x GTX 470 w/Zalman VF3000F/Corsair 850W PSU/Antec 1200/2xSpinpoint F3 500Gb RAID 0 |
#3 (permalink) | |
TechTin.com
this is a virus problem.TAke ownership in SECURITY tab.. To find security tab: Right click my computer-->>properties-->>security ![]() In security tab, there is an advanced option. There take ownership .But make sure you are loged as administrator or in administrator's group. you may not find security tab in properties.To enable security tab: start-->> my computer-->>tools-->>folder options-->>view-->>scroll down to the bottom of the list and clear Use simple file sharing [Recommended]. done.Now you can see security tab in properties of drives and folder.
www.9zap.com/forums -> Indian Webmaster Forum whost.in - Web Hosting Offers thinkdigit.com/forum/showthread.php?t=109137 TechTin.com Last edited by ravi_9793; 16-08-2007 at 12:41 AM. |
#4 (permalink) |
arre just run an anti-virus scan
shud detect any mailcious code and ur problem shud b solved u cud also search for ne autorun.inf dat will b stored as a hidden file and delete it an c if it solves ur problem |
#5 (permalink) |
That is a virus which comes via usb drives.
This thread should help u, read my post no.8 & post no.20 in that giving the solution. Cant Access My drive Others also have made suggestion in that post.
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how make make anyone(unregistered users) post on my blog? | kerthivasan | QnA (read only) | 5 | 23-07-2007 09:18 PM |
| prob wid wi-fi | chinmaythakur | Software Q&A | 7 | 02-02-2007 11:01 AM |
| help me with this prob :( | tinku dhar | QnA (read only) | 6 | 27-01-2007 11:05 PM |
| Pc Fan prob.(Pls help this interesting prob.) | Ishan | Hardware Q&A | 4 | 24-01-2006 09:38 AM |
