Old 15-08-2007, 11:47 AM   #1 (permalink)
Arrow Virus Problem. plz. help
Yesterday I was browsing Nokia site (probably u all know the reason why) when my PC turned off automatically.
Now whenever i try to boot it again, as soon as win xp loads it restarts again.
Plz. tell me what to do?
prabhatmohit is offline
Old 15-08-2007, 11:57 AM   #2 (permalink)
the man who sold d world
raina_rocks's Avatar
Default Re: Virus Problem. plz. help
may b its a ram problem...... chk out ur ram..... if its ok...... change d slot u put ur ram in.....
same thing happened 2 me few months ago......
Softwares r like sex,
they r better wen they r free!!!
raina_rocks is offline
Old 15-08-2007, 03:07 PM   #3 (permalink)
may be ram prob. check it with windiag or memtest.
abhijangda is offline
Old 15-08-2007, 04:36 PM   #4 (permalink)
How can the RAM problem occur? everything was working f9 till yesterday and even today i can load win xp on the PC but as soon as the desktop appears (in xp) , it again restarts.
Old 15-08-2007, 06:03 PM   #5 (permalink)
it can b a ram problem or ram slot problem......
it may occur suddenly..... chk out ur ram ..... try 2 clean it if its dusty.....
put it bac in other slot.....
Old 15-08-2007, 06:07 PM   #6 (permalink)
Still learning...
He28's Avatar
Hi prabhatmohit
Try this...
Boot XP in 'SafeMode' by tapping F8 key. Once you are in SafeMode, right click 'My Computer', click 'Properties'. A box will appear. In the box, click 'Advanced' tab. Look for 'Startup and Recovery' option and click 'Settings' button under it. A new box/window will appear. In that look for 'System Failure' option. Then uncheck the option 'Automatically Restart'. Then Click OK and OK buttons.
This should take care of issue.
Enjoy.
People laugh at me because I am different...,
I laugh at them because they all are the same...
This is... attitude!
He28 is offline
Virus problem, need online virus checking details-pls hava a read here. mobileman Software Q&A 2 14-04-2007 10:58 AM
A wierd problem.(Probably virus or hardware problem) spyder Software Q&A 2 09-01-2007 06:52 PM
virus problem q4_abhi Software Q&A 7 30-08-2006 09:30 PM
VIRUS Problem !!!!!!!!!!!!!!!! robs246 Software Q&A 3 20-11-2005 08:04 PM
mcafee virus scan 8.0 - problem updating virus definations infra_red_dude Software Q&A 3 26-06-2005 11:43 AM
