try using a15 day trial from nod32 and do upgrade it what u have seems to be a Trogen not a virus. Either way nod32 should clean ur system..and somtimes u may have to temporarly disable ur system restore and delete previous restore points if necessay.. some of these are pretty nasty..
Best of luck
To identify the virus try ctl+alt+shift and check for names like temp.exe or very long names or noname atall
try searching them out and make sure u can see both hidden and operating sytem files.
check for a file called autorun.inf in ur harddisk root directories.. if found delete it normally they are both hidden and marked as sytem files
to remove the hidden and sytem files attribute u could go to command prompt and go to where the file is and type> attrib -h -s <file name.extension>
eg: attrib -h -s autorun.inf
then delete it.
