This is a spyware dude,try gupta's step if not see this :
You should copy these instructions to a NotePad file for reading while in Safe Mode, because you will not be able to connect to the Internet to read from this site.
Please
download, install and update Avg anti spyware 7.5 from
http://www.ewido.net/en/download/ and dont perform scan yet
Print out the
Avg install and scan Instructions from
http://castlecops.com/t137442-CCSP_E...tructions.html
Please download
ATF Cleaner from http://www.atribune.org/ccount/click.php?id=1 DO NOT use yet..
Reboot your computer in
Safemode" using the F8 method. To do this, restart your computer and after hearing your computer beep once during startup [
but before the Windows icon appears] press the F8 key repeatedly. A menu will appear with several options. Use the arrow keys to navigate and select the option to run Windows in "
Safe Mode".
- Double-click ATF-Cleaner.exe to run the program.
Under Main choose: Select All
Click the Empty Selected button.
If you use Firefox browser - Click Firefox at the top and choose: Select All
NOTE: If you would like to keep your saved passwords, please click No at the prompt.
If you use Opera browser - Click Opera at the top and choose: Select All
Click
Exit on the Main menu to close the program.For
Technical Support, double-click the e-mail address located at the bottom of each menu.]
now
Scan with Avg per the "
Safe Mode" instructions you printed out.
IMPORTANT: Do not open any other windows or programs while Avg is scanning, it may interfere with the scanning proccess.
Reboot back to normal mode .
