Old 12-08-2007, 11:55 AM   #1 (permalink)
mayneu's Avatar
Unhappy which is the best rm to mp3 converter???
hi, i wanted to convert a rm format to mp3 format with best quality and that too in batches, i mean in groups at a time. not a single file at a time.
and the output quality should be best and the process should be faster. i dont mind buying it if its not available for free.... pls suggest me the best one......
mayneu is offline
Old 12-08-2007, 12:09 PM   #2 (permalink)
slugger's Avatar
Default Re: which is the best rm to mp3 converter???
y waste money wen u got a FREEWARE 2 do d job even better
RM to MP3 Converter
it also has batch-processing capabilities
slugger is offline
Old 12-08-2007, 03:58 PM   #3 (permalink)
mayneu's Avatar
its not the best yaar..... i tried converting .ram format mp3, it didnt recognise the file at all... so bad.....
real media format means all real format should be supported right???
even if its paid one it doesnt matter, pls tell me the most powerful and the best real media to mp3 converter....pls....
mayneu is offline
Old 13-08-2007, 08:34 AM   #4 (permalink)
u can try DBpowerconverter it does converts the format n do download its plugin too
i m, sorry tat, i m not able to remember d link but u search it in google u wud get it..
all d best
e17ad is offline
How to use 3gp converter? mandar5 Software Q&A 1 15-09-2006 04:44 PM
any .dat to mpg converter? jamyang312 QnA (read only) 13 03-09-2006 08:43 PM
*.vob converter maharajadhiraj QnA (read only) 4 08-04-2006 07:20 PM
PDF to PDB converter mako_123 Software Q&A 1 15-09-2005 06:23 PM
- by chris
