Old 11-08-2007, 11:31 AM   #1 (permalink)
Default Interuption while runnng CD/audio and copying files and vice versa
Hi All,
I could not understand what this problem is...
I try to copy a file from CD/DVD while my mp3 songs were played from system,there is a interruption
and the audio is disrupted.Also the mouse is jerked while moving in the screen.
The same is happening when i run cd/dvd audio from drive and do some file operation in the system.
However during this process,the system has more than 1 Gb free memory and cpu utilization is
around 50%.This is happening only when i deal with cd/dvd drives.
I have the following PC config
Intel Core 2 Duo E6700
MSI P6N SLi platinum
Win XP Pro Sp2(patch updated till jul 07)
LG DVD ROM and LG DVD writer(bought 2 yrs back)
2 GB DDR2 667MHz
80*2 GB SATA hard Drive
Avira Premium(Updated to Aug 3)
Audio Codec:realtek ALC888
GPU:NVidia xfx Geforce 8600GT 256MB
Is this problem due to audio driver or the DVD drive?Can anyone help me in solve this
issue?
Guhan
guhanath is offline
Old 11-08-2007, 11:46 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Interuption while runnng CD/audio and copying files and vice versa
What OS and Media Playing software ???
usually in Windows this happens if u have DMA Disabled... by default from Windows 2000 Microsoft made sure all windows ccome by default settings of DMA turned on.... how ever some time if u have virtual software like Demon Tools or such, to creat virtual CD/DVD drive some time they disable the DMA....
please check that whether the DMA is turned off or not... !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-08-2007, 07:44 PM   #3 (permalink)
Hi,
Are you saying me to disable DMA for the DVD drive?
I also want to add this.
The sound/Audio is getting dirupt only when I run DVD in drive.The Video Cd are running fine without any disruption
Guhan
guhanath is offline
Old 11-08-2007, 09:49 PM   #4 (permalink)
Rebooting
Hi,
NOpe, its oposite...
I am asking u to enable the DMA !!!!
rebooting
ChotoCheeta.com
Old 11-08-2007, 11:06 PM   #5 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Talking Re: Interuption while runnng CD/audio and copying files and vice versa
dude this is HDD being cluttred problem...defrag ur hdd around 3 times and then try....becoz the mouse becomes jerky when the sys files are not being read properly or are very cluttered .....and yes if the prb is occuring only when the dvd is being run means tht ur sys is getting overloaded try increasing the pagefile..and yes make sure DMA is turned on..u can also try running a disk cleaner........
Wadadadada!! ??
Ambar is offline
Old 13-08-2007, 03:38 PM   #6 (permalink)
Hi,
I will let you all know how it behaves in 2 days
Guhan
guhanath is offline
Interuption while runnng CD/audio and copying files and vice versa guhanath Hardware Q&A 5 13-08-2007 03:47 PM
Which game should be converted into a movie or vice-versa? dashingdhruv Gamerz 35 24-04-2007 11:00 PM
Convert audio to mp3 and vice versa KoRn Software Q&A 6 15-06-2005 11:30 PM
MP3 to WAV or vice versa abhinav QnA (read only) 10 12-05-2005 03:36 PM
- by chris
