Old 10-08-2007, 05:02 PM   #1 (permalink)
Default trojans and hack problems
My PC is keep getting attcked from a Hacker. I know him thats hacking because he threatened me to do that before it was actually hacked.Unfortunately he had all my ID passwrods somehow and did much damage Then I have resetted everthing back to normal. and bam he hacked in again....I cant seem to get how he cracks in my comp....Some guys suggested use of Firewall and anti spyware.. I installed them -SpyBOT Search and Destroy with updates]. Spyware found a TON of crap on my HDD. I cleaned it. Then cam firewall.. I installed Zonealarm. But It keeps on popoing with Setting it up and should I allow or block or somethign something stuff. I still not feel pretty safe..Can some one plz Guide me through Protecting from Internet Threats. I mean all threats I have Paypal and net banking on PC so cant compromise on security I am not a expert is comps so keep it simple plzThank you very much. I have N0D32 Licensed AV so never had Virus problems btw.
Tech_Wiz is offline
Old 10-08-2007, 05:12 PM   #2 (permalink)
Back in Power
almighty's Avatar
Default Re: trojans and hack problems
If u Installed ZA firewall then in my opinion u dont ve to worry any more...
Y don u turn ur firewall to auto learn...
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 10-08-2007, 05:20 PM   #3 (permalink)
Super Hero - Super Powers
n2casey's Avatar
And remember, to be in safe side, always keep ur password length at least 20 and ur password shud a combination of alphabets, numbers and special characters.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 10-08-2007, 07:08 PM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
I think he must've installed a keylogger on your system and thats how he got your passwords and all .. Get your pc checked by a good antivirus ...I'll suggest Kaspersky's Active Virus Shield .. Its free and very effective ..
Then you should install a firewall .. Here I'll recommend Comodo Personal Firewall ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 11-08-2007, 08:56 AM   #5 (permalink)
Does anything special needs to be done for setting up the firewall? and how to detect trojans? I read somewhere that AVs cant detect all trojans and need some special trojan removers etc. [rootkit and stuff like that :-/]
Tech_Wiz is offline
~**~ How Can You Get Infected by Trojans?~**~ jrkraj Tutorials 1 07-02-2007 03:59 PM
Trojans... Lord Vader Software Q&A 4 18-11-2006 01:48 AM
Places where Viruses & Trojans Hides readermaniax Software Q&A 6 11-12-2005 10:15 PM
Autopatcher infected with trojans??? drvarunmehta QnA (read only) 14 20-07-2005 07:54 AM
- by chris
