Old 08-08-2007, 09:47 PM   #1 (permalink)
The Sexy Beast
Angry Firefox Cache problem
Whenever my pc turns off with ff running(power cut) on the next reboot when i select either of "restore session" or "new session" it seems that ff looses it's cache memory and the pages take time to load than usual.
plz help me to get a solution.coz i have a airtel gprs(not edge) conn.
ratedrsuperstar is offline
Old 08-08-2007, 09:53 PM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: Firefox Cache problem
This is a bug or limitation or as Mozilla says a feature in Firefox
Sorry, if firefox crashes it deletes the cache. nothing can be done
about.me/gxsaurav
gxsaurav is offline
Old 08-08-2007, 09:59 PM   #3 (permalink)
The same happens with me too. YOU can just restart firefox or use %windir%\system32\rundll32.exe advapi32.dll,ProcessIdleTasks to recover excessive physical memory that it uses after reboot
ThinkFree is offline
Old 09-08-2007, 09:54 AM   #4 (permalink)
The Transcendental
If you love firefox llke me, you'll have to live with it.
Else, get opera. It is the best when it comes to cache management and browsing speed.
If RAM is an issue, IE7 may be better since it uses the explorer kernel.
Since you are on airtel gprs, i would strongly recommend opera.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 13-08-2007, 12:21 AM   #5 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
And not only it deletes the cache but deletes the browsing history too. Its very irritating.
navjotjsingh is offline
Old 13-08-2007, 01:24 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
yes its quite irritating ...... bt u have 2 bear it .........
& it does uses all ur cpu memory ............
... W H O T ...
ax3 is offline
L2 cache ??????????? spygamer Hardware Q&A 7 09-06-2007 12:04 PM
Where is the firefox cache? Simple_Graduate Software Q&A 3 13-02-2007 10:46 AM
is my L2 cache bad hansraj QnA (read only) 3 28-11-2005 08:20 PM
What is L3 cache? mohanty1942 QnA (read only) 3 08-02-2005 06:52 PM
- by chris
