Old 08-08-2007, 10:58 AM   #1 (permalink)
Shreyes P's Avatar
Unhappy Virus problem Plz Help
Every drive in my computer except the system Partition has a new option "Open(0)" which is set to default .So when i double Click on the drive instead of opening it will display a message saying " Access Denied ", every time i have to right click and then select open . Is this due to some virus? By any chance is there a virus by name "ctfmon.exe" ?
Shreyes P is offline
Old 08-08-2007, 12:29 PM   #2 (permalink)
Default Re: Virus problem Plz Help
ctfmon.exe is not a virus, but ur drive has a virus for sure which has modified the registry settings.
Do u have antivirus running or not?
ranjan2001 is offline
Old 08-08-2007, 02:20 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Try third option given here: [Windows] FreQuently AsKed ProBlems WITH SoluTions...
navjotjsingh is offline
Old 08-08-2007, 04:23 PM   #4 (permalink)
piyush gupta's Avatar
Best thing is to post yopur hijack this login and see if ur system is infected with any malware or not
piyush gupta is offline
Old 08-08-2007, 08:03 PM   #5 (permalink)
This thread should help u, read my post no.8 & post no.20 in that giving the solution.
Cant Access My drive
Others also have made suggestion in that post.
Hope it helps.
Old 08-08-2007, 08:11 PM   #6 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: Virus problem Plz Help
its not a virus... registry problem here
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 11-08-2007, 10:38 AM   #7 (permalink)
Shreyes P's Avatar
Talking Re: Virus problem Plz Help
Originally Posted by navjotjsingh
Thanks that link helped
Virus problem, need online virus checking details-pls hava a read here. mobileman Software Q&A 2 14-04-2007 10:58 AM
A wierd problem.(Probably virus or hardware problem) spyder Software Q&A 2 09-01-2007 06:52 PM
virus problem plz help gau_pppu Software Q&A 2 03-12-2006 11:06 AM
Virus Problem.... codeash Software Q&A 6 28-12-2005 11:00 PM
mcafee virus scan 8.0 - problem updating virus definations infra_red_dude Software Q&A 3 26-06-2005 11:43 AM
- by chris
