Old 06-08-2007, 08:08 AM   #1 (permalink)
Anindya's Avatar
Question Cassette -> mp3?
Friends i am planning to transfer songs from cassettes to mp3 or acd. Can anyone plz tell me what is the procedure to do it and what r the softwares required? Thanks.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 06-08-2007, 09:34 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Cassette -> mp3?
i cant suggest one Pro setup up though but I have done it with home made solution...
Pillips Walk Man (Cassate Player)
One 2 way Cord (Availavle in Chandi)
Nero Wave Editor
Upto Date Sound Drivers in System
Windows XP
Well the Idea is, 2way cord will come from Walk Man, Headphone out and will go in to ur computers Line in Port !!!!
Now in Wave Editor, Start Recording recording source will be line in instade of Mic in !!!!
Thats it, play the Cassate in walk man, and hit the record button in Nero Wave Editor...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 06-08-2007, 10:21 AM   #3 (permalink)
Always Questioning?
emailaatif786's Avatar
Question Re: Cassette -> mp3?
Why not Mic In?
Is there difference between MIC IN & LINE IN ? What further does LINE IN support?
:smile: Love Digit
emailaatif786 is offline
Old 06-08-2007, 10:30 AM   #4 (permalink)
slugger's Avatar
heres a FREEWARE solution 2 do d same
ADC Sound Recorder 3.4
u got to connect d cassete player thru d line-in of ur soundcard
u cud also try usin MusicMatch Jukebox
tho it has bcome Yahoo! music Jukebox dunno if d latest version duz dat or not, but musicmatch jukebox duz it. dat i no 4 sure
Originally Posted by emailaatif786
Why not Mic In?
u shud b able 2 record stuff from mic-in also but only real-life sound, musicmatchjukebox allows such recordin
thru line-in u d sound travels as electrical signals
slugger is offline
Old 06-08-2007, 10:56 AM   #5 (permalink)
Cool G5's Avatar
Post Re: Cassette -> mp3?
You can also use Audacity.
Just do exactly same as said by choto cheeta.
You will get the stereo to stereo cord for about Rs.50.
Cool G5 is offline
Old 06-08-2007, 11:11 AM   #6 (permalink)
Torrent Lover :)
akshaykapoor_3's Avatar
I remember doing this 2 years back with cool edit pro...If am nt mistaken, a tutorial regarding this ws published in digit magazine... as choto said a two way cable is just what you need and the s/w records the track using line in port !! Easy and interesting.. !!
akshaykapoor_3 is offline
Old 06-08-2007, 12:41 PM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
try searching DIGIT mag in old PDF files ...... u will find step by step guide with pictures 2 make the process easy ..........
sorry frd even i cant remember the month & year 4 article printed .........
... W H O T ...
ax3 is offline
Old 06-08-2007, 05:36 PM   #8 (permalink)
The Researcher
The volume should be kept at a optimal level. Otherwise your recordings will not sound proper.
Ramakrishnan is offline
Old 06-08-2007, 11:04 PM   #9 (permalink)
Anindya's Avatar
Talking Re: Cassette -> mp3?
Many thanks to all of u !
www.techani.com
Anindya is offline
Old 07-08-2007, 09:53 AM   #10 (permalink)
I had used Music Match Juke Box years back to convert many of my cassettes to CD and the quality was good. If I remember correct, it was a free SW then.
Output from cassette player should be connected to line-in only because it is amplified signal. Mic-in is to receive non amplified signal from a microphone.
V.Prem Kumar
janitha is offline
Old 07-08-2007, 01:18 PM   #11 (permalink)
Yeah,I'd second MM Juke Box.It had (the old ver atleast) some level setting option which you'd use to optimise the walkman's and line-in's volumes for the best recording level without clipping.
sashijoseph is offline
Old 07-08-2007, 01:33 PM   #12 (permalink)
Beware of the innocent
ilugd's Avatar
gave me an idea to try the same out with fm.
Life is too short. Have fun.
ilugd is offline
Old 07-08-2007, 05:08 PM   #13 (permalink)
Rebooting
Good TV tuner cards, like Pinnacle or WinFast, comes with FM support and software to record
rebooting
ChotoCheeta.com
Old 07-08-2007, 05:15 PM   #14 (permalink)
Norms Buster
You can use Goldwave with the MIC IN option.
VexByte is offline
Old 07-08-2007, 09:55 PM   #15 (permalink)
hailgautam's Avatar
I would recommended the use of Mp3MyMp3 to convert Cassets to mp3. It will directly encode the file to mp3 and is a free ware.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 08-08-2007, 06:58 AM   #16 (permalink)
Is actually a real word..
I always wanted to do this but every prog I use it doesn't sound 'great' (obviously) is there software editing tools that can clean up backround fuzz?
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Old 08-08-2007, 07:27 AM   #17 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
c that thread for enabling radio on PC, then simply use mp3mymp3 to record with line-in option.
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 13-08-2007, 02:25 PM   #18 (permalink)
Thumbs up Re: Cassette -> mp3?
the best software avlb in market is ''acostica spin it again'' it will help u converting audio cassete to mp3 with zero efforts as it detects the start and end of the track automatically, u need not do it manually
i love my computer :)
san85 is offline
Old 17-08-2007, 05:57 PM   #19 (permalink)
Attitude matters
Ponmayilal's Avatar
You can use Goldwave Digital Audio editor for recording and removing tape hiss from the tracks recorded in wave format without affecting music.
http://www.goldwave.com/
It is one hell of a lot program with lots of nice facilities to tweak your recording.The trial version has a limited number of commands but even if you exceed, you can save your project , close the program, restart, reload and continue. I used the program for years to convert all my cassettes to MP3s and at the end of it I was so pleased that I bought it to say “thank you”. You can record the tracks in wave format first, select a period of silence in-between the tracks where only tape hiss is present, copy it to the clipboard (this is called clipboard noise print) hit on the noisereduction tab, select the clipboard print preset and execute.Using the noise print the program eliminates tape hiss, wow and flutter without affecting the music.( power of digital processing).You can play around with various other features to enhance the music.You can then convert the wave tracks into mp3 using the same program or some other program like Razor lame with which you can tweak the mp3 encoder settings to end up in a professional sounding mp3s. My friends could never believe that these mp3s were sourced from cassettes.Of course there is a little bit of learning curve but you will enjoy trying your hand on it and once you are familiar there will be no going back. Try it and Good luck.
Ponmayilal is offline
Old 19-08-2007, 03:35 AM   #20 (permalink)
Thanks Ponmayilal for the software and the smal tut on how to do it, saves me the time with trying to fiddle with the program when I know what I am looking for. Once again Thank you kind Sir!
Liggy is offline
Old 10-09-2007, 04:29 PM   #21 (permalink)
Hi guys,
Once again I have come with a problem. When I have
old p3 comp, with frontech pci soundcard, I used to
record cassette songs to mp3 using my sony walkman
connecting it with line in jack using a stereo
cable.
Now I have pentium D 2.66 with D101ggc mobo, 5.1
creative inspire, with win xp sp2. There is a
auxilary male jack in the remote of the woofer. I
have connected the walkman in this jack with the
cable. I can hear the sound at the woofer. But
whenever I have recored the the sound, the output
file is blank, nothing is recorded. Even though I
have selected audio input from the volume icon of
the taskbar. I have used mmjb, cooledit pro,
goldwave, even win sound recorder, but prob
persists.
Infact I have connected my walkman directly to line
in jack. This time I cannot hear sound at the
woofer.Pls help me...
sghosh15 is offline
Old 10-09-2007, 04:53 PM   #22 (permalink)
NP : Crysis
xbonez's Avatar
i've converted tons of my dad's casettes to mp3s. i use casettet player connected to line in
Jet Audio to record, Wave Pad to split into songs (bec. jet records entire side as one file)
xbonez is offline
Old 10-09-2007, 06:34 PM   #23 (permalink)
ajayritik's Avatar
I used Music Match Juke Box couple of years back. I dont know what's the software available now.
ajayritik is offline
Old 11-09-2007, 12:09 AM   #24 (permalink)
Originally Posted by sghosh15
Hi guys,
cable.
cable.
persists.
Pl elaborate.
You have to connect the signal to the Line in of the sound card for recording.
V.Prem Kumar
janitha is offline
Old 11-09-2007, 12:18 PM   #25 (permalink)
As metioned by Janitha you'll have to connect the walkman to the line-in of the soundcard(and not the woofer).If you can't hear what you're recording, make sure the line-in control in the 'Playback Controls' of the mixer(double click the speaker icon) is not muted or set low.
Old 11-09-2007, 05:16 PM   #26 (permalink)
Well I have recorded many cassettes into mp3 earlier using my old comp. Yes I connect my walkman with line in jack of sound card. But in my new comp when I connect my walkman with the line in jack I cannot hear any sound at my speaker. I have also connected the walkman with the mic in. But nothing happned. I have changed the line in volume, but still I cannot hear the sound.
sghosh15 is offline
Old 11-09-2007, 11:28 PM   #27 (permalink)
maybe you have a faulty jack (computer or wire), or the volume on walkman is set low
Liggy is offline
Old 12-09-2007, 07:21 AM   #28 (permalink)
Smile Re: Cassette -> mp3?
Actually what happened as because I have a 5.1 woofer, in my Mixer it was selected 6 ch speaker, because my front and center speaker is connected with line in and mic in jack. When I m connecting my walkman with line in jack I am disconnecting both the front and centre speaker, now it becomes a 2.1 speaker. But my mixer selected as 5.1 speaker. Thats why I cannot hear the sound. Now I have selected 2.1 spekar at the mixer. Now it was fine. I have recorded the songs and the quality was also good.
I was recorded so many cass like this way, but then I have only a 2.1 speaker. So never faced such problem before. I was worried that what happed to my sound card. Now I m relaxed.
sghosh15 is offline
Digit released their cassette blueshift Random News 22 21-02-2007 07:33 PM
cassette to cd Shasta Software Q&A 18 07-12-2006 10:17 AM
needs mp3 cd to cassette - recorder shreyadr Software Q&A 4 25-03-2005 06:38 PM
Cassette to Cd ganesh_2218 QnA (read only) 8 18-11-2004 07:41 PM
