Old 03-08-2007, 12:40 AM   #1 (permalink)
in search of myself
CadCrazy's Avatar
Default Which antivirus can work with zone alarm pro/security suite
Tried many but no antivirus is working with zone alarm pro or zone alarm security suite?????????? Is there any av that can work with it?
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 04-08-2007, 06:34 AM   #2 (permalink)
Is actually a real word..
Default Re: Which antivirus can work with zone alarm pro/security suite
not fond of zone alarm, but usually if it says 'security suite' or something similliar it will come with a av scanner as well, if not you should be able to install an AV scanner just make sure that you give it access to the net (settings within zone alarm)
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Old 04-08-2007, 04:58 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
with zass u dont need an av, as the suite already has (kaspersky) av. with za fw, use avast freeware.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 04-08-2007, 05:12 PM   #4 (permalink)
Back in Power
almighty's Avatar
Question Re: Which antivirus can work with zone alarm pro/security suite
didnt get u mate
y u need another AV if u already installed ZONE ALARM SUITE
ZA suite has AV and spyware with firewall
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
should i remove zone alarm security suite if i install kaspersky internet suite??? tango_cash Software Q&A 4 01-08-2007 02:20 AM
Zone Alarm Security Suite problem tech_lover Hardware Q&A 5 10-07-2007 10:54 PM
Norton antivirus v/s Zone alarm imencoded128bit Software Q&A 17 05-08-2006 06:14 PM
Zone Alarm Security Suite 5.5.062.011 Issue nipun_the_gr8 QnA (read only) 3 30-06-2005 12:29 AM
ZONE ALARM ANTIVIRUS UPDATE ERROR vimalonline Software Q&A 2 13-04-2005 06:44 PM
