Old 31-07-2007, 08:59 PM   #1 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Unhappy HP/Vista woes 2 - HDsk not detectd in XP installation
I thought of having a dualboot system on my Vista.. with XP running as the other OS (compatibility probs with lotsa games & programs)... i partitioned my default C: drive in 160GB harddisk (i've another 160GB HD to.. dual HDs ) using Vista's disk management.. the new partition was easily detected & it works a breeze.
Then I'm supposed to install WinXP with it's boot disc.. copying started... & then the surprise.. a message stating that Windows XP didn't identify any HD!!! It read "ANY" harddisk.. when I had two!!! In the bios options(which were all set rightly), I analysed my HDs which were fine in all aspects. But the damn XP wasn't able to detect the HD.
That too after an Ubuntu installation last month happily detected & installed the OS (the Ubuntu is gone now.. & the drives are back to factory condition). Ubuntu realised the HDs but not WinXP!
Any ideas as to what went wrong.. & what can be done... I need an XP installation in my Vistaed HD. Dual booting, Dual partition...
koolbluez is offline
Old 31-07-2007, 09:41 PM   #2 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Default Re: HP/Vista woes 2 - HDsk not detectd in XP installation
remove ur Vista HD , n then install on Second HDD . this way both'll be isolated and u can select to boot anyone during startup .
I too have a 250+40 GB HDD setup and XP detecs both of em perfectly .
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 31-07-2007, 10:02 PM   #3 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
uhmmmm... it's a warrantied lappie.. & i cant take risks... also.. this might b a genuine prob... with the Vista OS or HP itself.. only those who tried it might b able to give the right answer... or it has to b some superior-men like the mvps mayb.... help.. ur good ol fly-guy has got some probs.. any1 help... batman... wonderwoman.. greenlantern... @least dumb ol' Flash!? Help...
Whither art thou?
Old 31-07-2007, 10:54 PM   #4 (permalink)
Hanging, since 2004..
tarey_g's Avatar
Your HDD is SATA and you will have to do slipstreaming, make a new installation of XP with your genuine XP cd that you have using nlite. Download sata drivers for your PC from the official HP website and add them into new installation via nlite. Xp installation will work perfectly then and will recognize your HDD with no probs during install.
PS - Pepsi tastes like monkey pee, not that i have tasted monkey pee but i can imagine the similarities after drinking pepsi. Coke/Thumb Up/ Mountain Dew rule!!
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 01-08-2007, 03:52 PM   #5 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
I've VISTA.. XP is not installed @ all.. it doesn't even install as the harddrives are reported missing by the bootable disc in the initial XP instalation phaze after copying files & b4 selecting of partitions to install into.
I need an easy way out... where are the other superheroes?
Acting like policemen.. always late... help.
Old 01-08-2007, 07:47 PM   #6 (permalink)
tarey_g's Avatar
Damn dude , did you read the solution i posted , it was exactly for the problem you are facing. Read it again please , we dont need superheroes weak people do.
Windows 8 ? :lol:
tarey_g is offline
Old 02-08-2007, 04:17 PM   #7 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
ahem.... re-read it... understood... but is there an easier way.. i don't want to nlite my xp now... no patience & the kind... and easier way needed..
Got ur method.. it is the best way out.. i suppose... but not the easiest... no mood to xperiment now...
XP SP2 installation woes Mangal Pandey Software Q&A 2 29-10-2006 09:48 PM
Seagate 160gb Hard Drive installation woes sysfilez Hardware Q&A 4 26-09-2006 11:12 AM
media centre installation woes ratedrsuperstar Software Q&A 4 27-08-2006 03:47 PM
.:: phpNuke Installation Woes ::. tuXian QnA (read only) 6 25-03-2005 08:57 PM
