Old 30-07-2007, 09:00 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default Problem
The problem is that my winXP does not show me the hidden folders.
Even if i enable the show hidden folders option. using SP2
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 30-07-2007, 11:45 PM   #2 (permalink)
pritishpaul's Avatar
Default Re: Problem
hmm..dont panik bro...hope u hv tried rebooting and checking those goddamn settings...see what might hv happend is that ur win registry's Dvalue must hv changed ..in this case u need to rectify that...ummm...digit gave this Dwords address in one of its issues(err..i cant remmember)...u can get their...hope that helps..
pritishpaul is offline
Old 31-07-2007, 01:19 AM   #3 (permalink)
slugger's Avatar
Default Re: Problem
heres wat u shud do
go2 registry
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\Advanced
in d right portion of d registry win u will c d hidden, just mod its value 2 1
its actually sum virus/worm [malicious script]
run a gud anti-* scan
u d guy whose been infected wit d pornware na
d00d ur comp has bcom a haven 4 malicious codes
use des tools 2 protect urself
Kaspersky Anti-virus
Spybot Search and destroy
Ad-Aware SE
yaar and in d future give better, descriptive titles 4 ur posts
slugger is offline
Old 31-07-2007, 09:10 AM   #4 (permalink)
chicha's Avatar
Default Re: Problem
HE HE HE. . yes i should do that. thank you.
chicha is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
