Re: Help with Bloodshed Dev c++!
You need to hold the window at the end, before exit. Use a cin.get() at the end of main (getchar if you're doing C). The other alternative (cleaner, in my opinion) is to run the program from an already existing DOS Shell.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
