Old 28-07-2007, 11:25 PM   #1 (permalink)
Default configuring home network on huawei wa1003a?
Hi team,
Just wanted to know whether it's possible to configure a local home network on huawei wa1003a that comes with dataone broadband?
I do not know what to call this thing - is it a modem or a router?
My intention is to play games like nfs on lan using wa1003a and also to connect to net. I have a desktop and a laptop.
Any links/help would do a great deal of help.
Thanks a ton.
Aman
Do, or do not. There is no try -- Jedi Master Yoda
imagineer_aman is offline
Old 29-07-2007, 12:30 AM   #2 (permalink)
slugger's Avatar
Default Re: configuring home network on huawei wa1003a?
dat is an ADSL modem, no good 2 setup a LAN [AFAIK, actually]
u need 2 buy a hub [alon wit a LAN card tho] 2 connect more than 2 comps or just 2 Lan card if 2 comps 2 b connected
search d forum for settin up a home network
Literally TONZ & TONZ of thread on dis topic available on d forum
slugger is offline
Old 30-07-2007, 06:32 AM   #3 (permalink)
Thanks slugger for clearing up this for me that wa1003a is just a modem.
Old 30-07-2007, 06:44 AM   #4 (permalink)
o yes its very much possible to set up a home network connecting your lappy to the router wirelessly and the desktop to the router through ethernet cable...search vinuthomas.com...there was an article/post about configuring it for home networking...I in fact setup my own network...can connect to my lappy thru my desktop(can play music files on lappy thru winamp on my desktop) but not vice versa..seems there's some problem!But one thing's clear ...networking is POSSIBLE.
a ship is safest at the harbour but thats not what its built for!
serendipiti is offline
Old 30-07-2007, 06:51 PM   #5 (permalink)
slugger's Avatar
OOPS!! didnt know dat wa1003a is a wireless modem, shud have checked it out first b4 postin
my mistake i apologise
slugger is offline
Old 30-07-2007, 07:09 PM   #6 (permalink)
Slugger...it's OK yaar no need to apologise!But cud you help me out in my prob?I have succesfully configured the networking..the laptop acn't access desktop(some access denied message is coming up!)but i access the laptop from desktop..and the two computers can be seen from the workgroup of each other!
Old 31-07-2007, 02:03 AM   #7 (permalink)
serendipiti - i had the same prob. for the wireless network config. so i bought a crossover ethernet 5m cable that cost me 50Rs. The computers have got connected and i successfully pinged them. However, when I try to play nfs underground 2 under lan option, i am unsuccessful.
Too Bad - just found out that there may be a problem with crossover
http://support.ea.com/cgi-bin/ea.cfg...i=&p_topview=1
Last edited by imagineer_aman; 31-07-2007 at 02:05 AM. Reason: Automerged Doublepost
How to forward ports in Huawei Wa1003a series ADSL router? abhijit_reddevil Networking 9 06-01-2007 07:32 PM
Where is web based Configuration Manager of huawei WA1003A eagle_y2j PC Components / Configurations 1 14-04-2006 02:16 AM
configuring network settings in linux through LAN card sunil.p Open Source 3 04-02-2006 08:33 PM
Configuring Network on 2 Win98 PC SystemError Tutorials 3 22-12-2005 09:54 PM
