Old 26-07-2007, 10:45 PM   #1 (permalink)
the man who sold d world
raina_rocks's Avatar
Unhappy HELP XP installation
i connested my hdd with my frnds pc n thn deleted formatted it n thn wen i wantd 2 install back win xp on my pc..... it cudnt install coz i hav an outdated mothr brd..... n d bios doesnt work properly....
so my questn is can i install xp by connectin my hdd on sm other pc...... or it has 2 b installed only wen connected 2 mine(coz u hav 2 mak sm installations frm ur driver cd)
n can i install win 98 or sm othr os while my hdd is connected 2 sm othr pc n thn install xp l8r wen i connect it 2 my pc????
plz help!!!!
raina_rocks is offline
Old 26-07-2007, 10:56 PM   #2 (permalink)
Cool and Calm
abhi_10_20's Avatar
Default Re: HELP XP installation
is the OS original?
When Roger's at play, opponents pray..!!!!! :twisted:
abhi_10_20 is offline
Old 26-07-2007, 10:57 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Well in 98 yes, Windows 98 can be installed in a HDD Connected to System A then remove that HDD and attach with System B and run again without installaion of OS again wtih not much of a problem....
In case of Windows XP, it because very un-reliable !!! Driver issue max of the time through up many issue hence makes the computing slow and difficult !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 26-07-2007, 11:01 PM   #4 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Smile Re: HELP XP installation
plz help!!!!
AFAIK u can install xp by connecting to another hdd but when u will
connect ur hdd on ur motherboard its possible( not sure) that XP will not
start .
on windows 98 i think there will not be any problem . i have done it
give it a try
saurabh kakkar is offline
Old 26-07-2007, 11:18 PM   #5 (permalink)
Alive Again...
satyamy's Avatar
yes like win98
this is not possible in winXP
i tried to install XP on 2 approx same PC config
I attached HDD to 1st PC install XP & attach that HDD it to 2nd PC
but XP dosent RUN
satyamy is offline
Old 27-07-2007, 09:55 AM   #6 (permalink)
is it possible to do this wit any othr o.s???
Old 27-07-2007, 10:41 AM   #7 (permalink)
Rebooting
Can u tell us whats the problem installing the OS in ur native computer ?? as if u are facing hardware error while installing an OS, make no miss-take, u will face that same problem while running the OS...
rebooting
ChotoCheeta.com
Old 27-07-2007, 04:13 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
98 mein chalta tha .......... bt 4 XP, it should b installed with ur ur motherboard & other parts [ur pc] only ..........
... W H O T ...
ax3 is offline
Old 27-07-2007, 08:05 PM   #9 (permalink)
slugger's Avatar
u must install sysprep on d hdd after installation b4 taking it back 2 ur own comp
slugger is offline
Old 27-07-2007, 08:10 PM   #10 (permalink)
Rebooting
we are all missing the point, the reason his is showing for the purpose will not help with any method, if u are unable to install OS because of Hardware issue, nothing will ensure smoth running
rebooting
ChotoCheeta.com
Old 27-07-2007, 08:13 PM   #11 (permalink)
slugger's Avatar
totally agree with choto_cheeta babu. sumwer down d line d discussion drifted into wether it is possible 2 run an OS from d HDD wen d installation was dun on sum other config comp. me 2 a culprit.
slugger is offline
Old 27-07-2007, 09:02 PM   #12 (permalink)
no thr is no prob in my h/w as i used 2 run xp n 98 bfore........ but d prob is wit d mthrbrd tat it is outdated n d bios setup is too bad...... i cant even change d boot option.......
i think 98 will wrk..... i will try it n tell u ppl l8r..... nyways thanks
Old 27-07-2007, 09:52 PM   #13 (permalink)
slugger's Avatar
if u had installed XP on urcomp once den mobo dated outdated makes no diff [unless of course u tryin 2 say dat d ur mobo is damaged, which i dont think u r trying 2 say]
as 4 ur bios wat does too bad mean and y r u not able 2 change d boot option
r u gettin any error message
if u cud elaborte on these points d members wud b in a better position 2 help u
also r u getting ne error messages during installation of XP?
slugger is offline
Old 30-07-2007, 12:48 PM   #14 (permalink)
luk...... i cant explain u evrything..... i cant change my bios settings coz thrs no option to change sm of thm........
nyways thanks to u ppl......
its done..... i frst installed 98 n thn connect d hdd 2 my pc...... (ie my mobo)
thn installed xp..... n removed d 98..... its workin....
thanx
Other installation cd with own key rksingh Software Q&A 3 08-04-2007 10:59 AM
nsu installation help rksingh Mobiles and Tablets 8 10-02-2007 07:24 PM
FC6 app installation Vivek788 Open Source 3 13-01-2007 09:43 AM
XP installation ! ! ! ax3 Software Q&A 8 31-10-2006 11:18 AM
VB.NET Installation ra_sriniketan QnA (read only) 2 10-09-2005 09:45 PM
