Old 22-07-2007, 08:53 AM   #1 (permalink)
napster007's Avatar
Default Sos Help!!!!!
guys i have a problem. in my xp some icons are missing like the shutdown option. what do i do??? there is no run option too
napster007 is offline
Old 22-07-2007, 01:10 PM   #2 (permalink)
Try me
shantanu's Avatar
Default Re: Sos Help!!!!!
first install a good AV and scan your system for virusses.....
now insert your windows XP cd and press WINKEY+R the run dialog box will pop up... now type SFC /SCANNOW
it will take some time for windows to again restore files from disc and your problem will sort out..
write again if this does not solves the problem..
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
Old 23-07-2007, 01:08 AM   #3 (permalink)
Yalam
Right click on this http://www.kellys-korner-xp.com/regs_edits/noclose.reg and choose Save Target As...save it to your desktop. Now double click on that noclose.reg file and choose Yes to add it to the registry. See if the shutdown entry returns after doing that (or after a restart).
to get run back try these
Right-click on the Start button
Click on Properties
Select the Start Menu tab
Press the Customize button
Select the Advanced tab
Scroll down through the Start menu items list
Check the box next to Run( uncheck and recheck if already checked)
Press OK twice
if it doesn't work try this
  • Go to C:\WINDOWS\system32\gpedit.msc
  • Go to User configuration -> Administrative Templates -> Start Menu & Toolbar
  • Double click on Remove Run from start menu
  • Select Disable, then press OK
or,
In registry go to
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer
Create new DWORD Value called NoRun and set its value to 0.(might require restart)
Hope it works.
Yavin is offline
Old 23-07-2007, 04:56 PM   #4 (permalink)
napster007's Avatar
thanks guys very much but anyway yesterday my xp dint boot.(passed away i guess). i had to format and reinstall it. thanks for taking so much pain.
Old 23-07-2007, 05:04 PM   #5 (permalink)
piyush gupta's Avatar
ohh so sad
didn't u tried XP reinstall feature
piyush gupta is offline
