| Forum |
#1 (permalink) |
Proud to be Linux
setup is inspecting....." after that the screen goes blank.i tried my friend's xp cd also with same results.please help me. |
#2 (permalink) |
Still Shining!
Your Master Boot Record has gone bad. Connect your Hard drive to some other computer, and remove all the partitions.
Repartition and format again. Now connect the HD to your computer and XP setup will work properly.
Simplicity is the ultimate Sophistication HP dv6 6121tx: Core i7 2630 QM | 4GB | AMD 6770M 2GB GDDR5 | 640 GB Nokia N86 8MP |
#3 (permalink) | |
Wire muncher!
do one thing, disconnect ur hdd and try booting off the cd. even the cdrom drive cud be the culprit. do other CDs read and copy properly? u may even try resetting the bios settings to their default and try. since u've tried wid ur fren's xp cd too, the problem seems to wid ur hardware or settings.
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#4 (permalink) |
Still Shining!
IR dude, I have faced this many times. Sometimes unistalling Kaspersky damages the MBR. And XP bootable CD isn't detected anyway, once the mbr goes bad. No need to remove all partitions. Just delete the active partition, assign a new primary partition and make it active. That's it.
#5 (permalink) |
Wire muncher!
^^^let him confirm before deleting the partition. coz if he does that and problem turns out to be something else then he'll hafta reload everything. thats a real pain. thats why i asked him to disconnect the hdd and try booting. try connecting some other hard disk. that'll clear things up.
#6 (permalink) |
Is actually a real word..
I had simmillar problem and all I did was make sure Bios had correct settings for and then I removed a jumper on HDD. and then I booted to recovery console and did fixmbr. took me a while but when I finally got it, it was a lot beter then refrmatting
“They put me here because I’m from Canada and they think I’m slow, eh?..." |
#7 (permalink) |
Still Shining!
But the problem is sometimes winxp cd doesn't bring up "recovery console" prompt.
#9 (permalink) |
Proud to be Linux
my hdd is ok as i already have a working copy of xp on it.my xp copy is installed abt 4 years ago and so some of files are corrupt.i have to repait it.
i have resetted bios settings and my cdrom is quite good as it doots fedora cd's well and good. |
#10 (permalink) |
so you can boot into winodws then? did you try a sfc /scannow? is there a I386 folder on your c: Drive? if not copy from the CD and install on c:. boot to safe mode with command prompt... c:\i386\winnt32.exe /cmdcons. or you can run this command from within windowsXP d:\i386\winnt32.exe /cmdcons (d: being your cd drive)(next time u boot up should give you option to enter recovery console.
#11 (permalink) | |
Booting Nicotine!!
<edit> post ur config plz
http://spironox.blogspot.com Rig : Asus P4 p 800SE ( happy ) Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004) Last edited by spironox; 22-07-2007 at 07:46 PM. Reason: forgot ! |
#12 (permalink) | |
Proud to be Linux
intel 945 p4 3.2ghz guys just did a ram test using windows memory diag and all the tests failed.what does this mean.i had a psu failure abt a week ago.since then xp cd not booting,frequent restarts.and also recovery console is not starting..... what does it mean?ram fried??? Last edited by abhinandh; 22-07-2007 at 08:55 PM. Reason: Automerged Doublepost |
#13 (permalink) |
This problem arises due to bad cds. When i had win xp, i copied the cd. The original cd from which i copied worked but the copy didn't work even on my frnds pc. Copying was successful though.
KDE on ArchLinux PHP, MySQL, PostgreSQL, Linux, Apache; Message me to hire (freelancing only) Explore Technology @ http://www.itech7.com Cheap and Reliable VPS Hosting @ http://j.mp/arHk5e |
#14 (permalink) | |
Booting Nicotine!!
http://spironox.blogspot.com Rig : Asus P4 p 800SE ( happy ) Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004) |
#16 (permalink) |
Still Shining!
^^Yup, sometimes they do damage the MBR. Read it on their forums. Faced the same problem twice until I found this tool from their site, which unistalls it safely.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| A wierd problem.(Probably virus or hardware problem) | spyder | Software Q&A | 2 | 09-01-2007 06:52 PM |
| a really wierd problem | vikram | Software Q&A | 2 | 15-05-2006 10:49 AM |
| Wierd problem with my net | drvarunmehta | QnA (read only) | 4 | 04-02-2005 11:23 PM |
| Wierd Problem with my Windows!! | 144 | Software Q&A | 5 | 16-10-2004 05:54 PM |
