Old 20-07-2007, 12:58 PM   #1 (permalink)
demoninside9's Avatar
Default Help me please
I have p4 system with asus 845 mainboard. I bought a new 80GB HDD n install it, n I already having a 60GB HDD. I m facing a problem, whenever I switch on my compute it takes me in BIOS n says "set up ur CPU speed",ur system may hang(in red color). I set date n time whenever I login but it shows the wrong time n date.
pls help me if anybody knws the prob.
there is no shortcut for SUCCESS
demoninside9 is offline
Old 20-07-2007, 04:03 PM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: Help me please
ok it is the problem with your cmos battery,if u had warranty replace it it's just a price 0f 35Rs
Batistabomb is offline
Old 21-07-2007, 12:09 AM   #3 (permalink)
g_goyal2000's Avatar
Yes, it's battery problem. It would be foolish to invoke warranty just to replace a battery.
35 rs. if u buy a maxell, sony or any other good company.
10 rs. if u buy a local one.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 21-07-2007, 12:27 AM   #4 (permalink)
From when r u facing this problem i.e is it after as soon as u installed ur new HARD DISK ..Try wat mates said ..it wil surely work
iceeeeman is offline
Old 23-07-2007, 01:43 PM   #5 (permalink)
Thanks
- by tv6952
- by soumya
