Old 20-07-2007, 11:23 AM   #1 (permalink)
lazy bone
Default External Casing+DvD burner giviing burning fail error ?
alright 1st read my post carefully .
I bought external casing with USB contact to my laptop for my AsuS DvD writer. I have attached it in external casing , power supply & all other things are okay. Pushing eject button -> drive is coming out & going in that also works fine .
now the real problem , I made an "Iso file " from best of Rajkapoor video files using imgburn . Output file is "Rajkapoor.iso"
I used imgburn , Alcohol 120 % & Nero but all of them failing , Nero showed message like "DMA Driver error"
while imgburn showed something else
Alcohol showing this kinda error
http://img267.imageshack.us/img267/9333/82752956vt5.jpg
used to these programmes while my Asus DvD writer was in Desktop & never gave any error but it stopped burning since when I fitted it in external casing
my OS is Win Xp so driver should be no problem (I hope )
wht is weired is that I checked my previous burned DvD (data & Video) both are reading fine in this external DvD
any sollution /suggestion ?
if this problem belongs to other section do move to whichever suitable.
multi is offline
Old 23-07-2007, 12:37 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: External Casing+DvD burner giviing burning fail error ?
delete this ISO file & try creating a new 1 ...... & c if u get this error again ....
or mayb cd/dvd is copy protected ......
... W H O T ...
ax3 is offline
External HDD with casing not working plzzz help blacklisted Hardware Q&A 1 01-08-2006 05:11 PM
external HDD casing query blacklisted Hardware Q&A 3 01-08-2006 01:38 PM
Trouble using Old HDD through External Casing sakumar79 Hardware Q&A 3 03-05-2006 11:39 AM
Internal DVD writers + External Casing?? Is it possible??? tarun_34 QnA (read only) 1 25-03-2005 10:12 AM
