| Forum |
#1 (permalink) |
M$™ Certified Spammer
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l |
#2 (permalink) |
Deadman Walking
ok try to clean registry using tuneup utilities,regcleaner and system mechanic professional and try to defragment once a week and also try ashampoo winoptimizer and remove all temporary internet files,and all bnackup files
#4 (permalink) | |
u must disable all services not useful 2 u [read d description in fornt of service name]and set d non-critical services 2 manual instead of automatic
ur hdd fre space [2nd one] is not small enuff 2 cause problem just 4 kik, try using only d hdd dat has got d os installed and keep d other physically deatched from comp, and c if it makes any differen yaar u din't have 2 start a diff thread again, u cud have just post in d earlier thread and people wud've replied if dey knew a soln Quote:
since u brought up event viewer, entrana u must have a look thru d event viever and c d errors and wrning events, it cud give u an idea as 2 y ur rig is acting up Last edited by slugger; 20-07-2007 at 05:00 PM. |
#5 (permalink) |
uhh whats event viewer, i dunno whats casuin the problem really im trying to offload junk to dvds then will tell ye guys
hey theres another error saying ip address conflict with another computer how to resolve this
#6 (permalink) |
4 d location of Event Viewer
Start>Settings>Control Panel>Administrative Tools>Event Viewer as 4 ur IP address conflict Microsoft's solution or y don't u just try loging off and den logging back on 2 c if u r assigned another IP by d ISP, dat is i'm ssuming dat u r directly connected 2 d ISP's WAN usind d ADSL modem, in which case ur IP is dynamicallly assigned by d ISP u cud also try dis out open commmand prompt and go 2 d C: drive [go 2 d root] and type in d foll Code:
ipconfig /release Code:
ipconfig /renew c if u get another ip and r able 2 access d net |
#8 (permalink) |
im i use sify broadband and they have their own connecting client thingee it dooesnt use the microsoft connect to internet i have no modem or router its through cable
#10 (permalink) |
guys whats nero dma manager i cant seem to tick the check box of my dvd burner
and it still takes 1 hour and 40 minutes to burn a dvd guys what is wrong with this piece of **** it wasnt like that before any ideas and my dvdr drive wont run on dma mode (direct acces memory) have no idea what that is but it wont run on that HELP GUYS do i have to reinstall windows or something nvm i fixed it u guys cudnt do nothing muahahahahaha just kidding dont hunt me down and slaughter me close thread
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l Last edited by entrana; 24-07-2007 at 05:20 PM. Reason: Automerged Doublepost |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need the MJPG (Motion JPEG) Encoder | sushantvirdi | QnA (read only) | 1 | 25-01-2007 09:29 PM |
| algorithm of robot motion planning | Saharika | Networking | 1 | 14-06-2006 09:05 AM |
| Motion picture screensaver (Not Video !!). | Kannan | QnA (read only) | 1 | 27-04-2005 05:43 AM |
| SLOW MOTION GAMES | satya | Gamerz | 6 | 09-01-2005 11:53 PM |
