Old 17-07-2007, 09:35 AM   #1 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Default IE7 problem!!!
I need help! whenever i click the address bar on ie7, it starts to shake and it keeps going untill i press alt and during shaking i can't type anything!!! if i press alt i can't type anymore. but it sometimes works without shaking???
I'm back! Gimme a hugggggg...
cooldudie3 is offline
Old 17-07-2007, 10:13 PM   #2 (permalink)
a_tif's Avatar
Default Re: IE7 problem!!!
if possible give a screenshot
a_tif is offline
Old 17-07-2007, 10:21 PM   #3 (permalink)
slugger's Avatar
how can he give u a screenshot of a shaking-whatever
@cooldudie3
wat shakes d address bar or d browser window?
wat abt any other windows dat may b open @ dat time. do they also shake?
slugger is offline
Old 19-07-2007, 03:27 PM   #4 (permalink)
scan your computer
abhijangda is offline
Old 29-07-2007, 10:37 PM   #5 (permalink)
I had the same problem for months. i finally found the answer here: http://blogs.msdn.com/tonyschr/archi...ng-glitch.aspx
I hope that helps
breitinger is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
