Old 16-07-2007, 11:40 AM   #1 (permalink)
Default Problem with NLite
I tried Nlite for the first time to create a Win XP Cd/DVD with all hot fixes, drivers etc. I used genuine XP. I was able to integrate autopatcher but integrating drivers seem impossible. I had copied all drivers like chipset, graphics, audio, monitor etc. to the D drive and had used them at the time of the last installation. I am not able to integrate any of these with Nlite. Thinking that it was because of absence of .inf files, I tried extracting them with Winzip as suggested in the Nlite site but still unsuccessful.
Hope somebody will help.
V.Prem Kumar
janitha is offline
Old 16-07-2007, 04:43 PM   #2 (permalink)
Noobie Pro
alsiladka's Avatar
Default Re: Problem with NLite
Copy all the drivers to a folder, and direct nLite to that folder. Dont change any of the files from that drivers folder. You will have to extract all the files from a zip archive or an Exe archive before nLite will be able to detect the drivers.
www.twitter.com/alsiladka
alsiladka is offline
Old 16-07-2007, 04:56 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Agree
http://www.nliteos.com/guide/part2.html
rebooting
ChotoCheeta.com
Choto Cheeta is offline
How 2 use nLite???????????? Naveed Software Q&A 1 26-01-2007 03:08 AM
