Old 15-07-2007, 08:13 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default sony DVD writer
i purchased sony DVD writer i think its 830A or some thing like that 4-5 months back.
i did not face any problems reading cd's , dvd's or burning them.
recently some of the dvd's burned at my friends are not being read by my rom
it shows as an empty which are working some where else.
But i am able to read other cd's dvd's.
first i thought it was cause of the buring speeds or some thing like that.
but it does not add up.
please help.
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 15-07-2007, 10:47 PM   #2 (permalink)
Is actually a real word..
Default Re: sony DVD writer
what software r u using to burn the CD's and are you finalizing the cds, ore leaving them open to burn more data later.
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Old 15-07-2007, 11:27 PM   #3 (permalink)
slugger's Avatar
if u r using NERO @ ur friend's place 2 burn d DVDs then enable disk verification option b4 u burn anymore disks. d fact dat u r able 2 read disks burnt elsewhere means dat d problem has something 2 do with d burn process used ur friends place
@Liggy
i dont think dat enabling multi-session option shud cause problem with reading disks, esp if d drive is 4-5 onths old
slugger is offline
sony dvd writer help mohitgiri Hardware Q&A 2 09-02-2007 05:19 PM
DVD WRITER *SONY* or *HP* karthik55859 Hardware Q&A 4 29-07-2006 01:15 AM
Which dvd-writer sony dw-q120a or sony dru-820a its urgent anirudhasarawgi Hardware Q&A 3 27-05-2006 05:47 PM
DVD Writer from SONY deni3x Hardware Q&A 8 05-11-2005 07:46 PM
Sony DvD writer readermaniax QnA (read only) 1 26-07-2005 08:33 PM
