Old 15-07-2007, 10:57 AM   #1 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Computer Slow in odd way HELP PLEASE
guys this is weird in my pc when i install something, the mouse starts moving very weirdly like games with low framerates like framreates of 40 or something.
ill post a video
and it also takes a long time to burn now i dunno why any guesses?
http://rapidshare.com/files/42987549/MOV00003.3gp.html
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 15-07-2007, 11:10 AM   #2 (permalink)
slugger's Avatar
Default Re: Computer Slow in odd way HELP PLEASE
this usually happens when ur CPU is under max utilisation. i face this problem when i convert files using dbpoweramp, when d rig becomes almost unresponsive 2 other tasks
also it wud not be a bad idea 2 run a good anti-* scan 2 rule out d possibilty of ur rig being infected
slugger is offline
Old 15-07-2007, 12:01 PM   #3 (permalink)
entrana's Avatar
i think its a virus man its just gettin weirder and weirder must use avast antivirus im using a crappy zonelabs antivirus
this didnt happen before man do i have to reinstall windows now
entrana is offline
Old 15-07-2007, 12:34 PM   #4 (permalink)
also try monitoring the temp of CPU...it may be the case of heating if its overutilised for a long time.
Abhishek Bhattacharya
abhishek_del is offline
Old 15-07-2007, 12:42 PM   #5 (permalink)
piyush gupta's Avatar
Check ur CPU fan first weather its running fine or not
also post you HijackThis Log File here
piyush gupta is offline
Old 15-07-2007, 03:04 PM   #6 (permalink)
entrana's Avatar
whats a hijack this file
could be because of the dust inside the cpu
some files like windows security and crap wont even start its not virus i scanned with avast professional,registry mechanic,spybot and other crap its clean
just cleaned my pc of dust done but dude programs wont run now like windows security and stuff WONT ****ING RUN
entrana is offline
Old 15-07-2007, 03:35 PM   #7 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
HijackThis is a utility that produces a listing of certain settings found in your computer. HijackThis wills scan your registry and various other files for entries that are similar to what a Spyware or Hijacker program would leave behind.
Visit the following link for tutorial on Hijackthis:
http://www.bleepingcomputer.com/tuto...utorial42.html
Run the scan save the logs and then paste it in the forum. Guys here should be able to help you identify the culprit.
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 15-07-2007, 08:04 PM   #8 (permalink)
entrana's Avatar
i think i may know the cause well its kinda weird and u wouldnt believe me anyways
this happened before i think automatic update (for xp) didnt complete so i think this is it still waiting for automatic update TO update its not coming its not starting
i THINK something like this happened before regarding automatic updates weird huh
EDIT: nope nope the automatic update just solved the program runnin problem it still has low framerates when i install smoething ,installations are slow and burning a dvd took me 1hour and 25 minute at the speed of 1percent per minute god dammit
entrana is offline
Old 15-07-2007, 10:53 PM   #9 (permalink)
Is actually a real word..
so u took ur case apart and blew out all the dirty crap. how muxh free space is on your computer, how many HDD's or partitions do you have. better question how much RAM do you have!? how many time do you run diskcleanup/defrag. how many services/startup items do you have running in the backround. run a chkdsk /r and/or sfc /scannow. I too would suggest you download and run hijackthis and post here. or read this thread by Mr. Vista MASTER TUTORIAL: Make Your Windows XP Super Fast !!!
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Old 16-07-2007, 06:38 AM   #10 (permalink)
entrana's Avatar
no no ive done all the crap my ram is 1 gig i used to have to same settings before but it aint work like this i think cuz its world of warcraft dunno
entrana is offline
Old 17-07-2007, 10:19 PM   #11 (permalink)
entrana's Avatar
yup it was world of warcraft dunno why but i definitely wasted my money on that at least my pc is fine now
entrana is offline
Old 19-07-2007, 10:26 PM   #12 (permalink)
entrana's Avatar
Question Re: Computer Slow in odd way HELP PLEASE
no it wasnt wow but anyways mods close this thread please
entrana is offline
Computer Slow boosters QnA (read only) 7 04-05-2007 11:12 AM
Win Xp sp2 too slow magneticme200 Software Q&A 3 29-04-2007 12:04 AM
Problem with Computer slow speed abhipal Hardware Q&A 5 22-04-2007 02:18 PM
computer is working very slow & unstable ajeet_00 Software Q&A 7 06-01-2006 11:15 PM
Slow XP ashisharya Software Q&A 18 13-03-2005 11:26 PM
