Old 14-07-2007, 05:34 PM   #1 (permalink)
Default gmail pop3 problems
I am unable to download mails from gmail via POP3 in Outlook Express.
I get the following error message:
The connection to the server has failed. Account: 'GMAIL', Server: 'pop.gmail.com', Protocol: POP3, Port: 995, Secure(SSL): Yes, Socket Error: 10060, Error Number: 0x800CCC0E
Any workaround for this issue.
Thanks in advance.
mehman is offline
Old 14-07-2007, 06:05 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: gmail pop3 problems
try these
http://members.connectto.net/email/o...0x800CCC0E.htm
http://forum.theispguide.com/isp-ftopic4877.html
just try googling. I had a problem in our ambala office once and i did something which sorted it out. It was over a month ago so i don't remember, but I did use gmail troubleshooter. Download from here.
http://dl.google.com/gmailpoptrouble...rInstaller.exe
Hope this works. Do get back on your success or failure.
Life is too short. Have fun.
ilugd is offline
Old 14-07-2007, 06:47 PM   #3 (permalink)
Thanks in advance.
Have you enabled POP3 in your GMAIL account
troubleshooter is offline
POP3 Help for Gmail raasm287 Internet & WWW 13 10-07-2007 08:26 PM
gmail POP3 error tusarks Software Q&A 10 04-07-2007 10:24 PM
pop3 ? redhat_adi QnA (read only) 16 15-12-2004 10:48 PM
Can someone here develop a Gmail-POP3 software extension ? ceo Software Q&A 9 20-09-2004 06:02 PM
