I need some help. My mtnl triband 256 unlimited is a bit troublesome today.
I am not able to open gmail, yahoo and many othersites. Digit opens fine and google does too.
but when i try to open gmail, yahoo and most other sites, all it get is "connecting to <website>" in the status bar and after 3 minutes or so, I get a problem loading page - connection has time out error.
Could someone help me on what to do? I don't think the techsupport will be able to help me on this. Any settings to be done on the router?
Pinging the addresses also doesn't work though the dns seems to work since i get the ip addresses during the ping.
C:\Documents and Settings\Jeba Singh Emmanuel>ping www.google.com
Pinging www.l.google.com [64.233.189.104] with 32 bytes of data:
Reply from 64.233.189.104: bytes=32 time=891ms TTL=245
Reply from 64.233.189.104: bytes=32 time=995ms TTL=245
Reply from 64.233.189.104: bytes=32 time=657ms TTL=245
Reply from 64.233.189.104: bytes=32 time=572ms TTL=245
Ping statistics for 64.233.189.104:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 572ms, Maximum = 995ms, Average = 778ms
C:\Documents and Settings\Jeba Singh Emmanuel>ping mail.google.com
Pinging googlemail.l.google.com [209.85.199.19] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 209.85.199.19:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
thinkdigit opens fine and that is what i am using to post this. So it is a pretty silly error.
What do I do? Please help. My bitcomet works fine.
