Old 01-03-2005, 04:21 PM   #1 (permalink)
Default problem opening of firefox
hi friends
i m ashish here. i wanted to knw why it takes time to oipen fire fox it set to default browser but when i click on firefox icon it takes hell of time to open . i even reinstalled ......firefox.exe please help me out
ashishkamat is offline
Old 01-03-2005, 04:30 PM   #2 (permalink)
swatkat's Avatar
do u use any AntiVirus?
http://swatrant.blogspot.com/
swatkat is offline
Old 01-03-2005, 04:41 PM   #3 (permalink)
Default ya
ya i use avg antivirus 7.0.306 latest one
Old 01-03-2005, 04:46 PM   #4 (permalink)
enoonmai's Avatar
Please post your system specifications, and run a complete, thorough scan of your system with the updated antivirus programs. Also download and run HijackThis from here:
http://www.spywareinfo.com/~merijn/downloads.html
and then save the log and post it back here. This way, we can take a look at what processes are running and tell if you're infected with a virus that may be causing your computer to slow down.
In the meantime, if you're running Windows 2000/XP, hit Ctrl+Shift+Esc and go to the Task Manager, and on the Processes tab, click the CPU label and find out the name of the program that's got the highest CPU value. If its anything other than "System Idle Process" let us know.
Playing FEAR XP/LSW2
enoonmai is offline
Old 01-03-2005, 04:46 PM   #5 (permalink)
swatkat's Avatar
i thought AV scan in background is causing the delay...but Avg is not that resource hungry...
what's ur system config?......disable unnecessary background/startup processes
Run Disk Defragmenter regularly....
swatkat is offline
Old 01-03-2005, 05:18 PM   #6 (permalink)
Default hie
hi buddies
i m using winxp sp2 (on d drive where the problem isand windows 98 on c drive),256 ddr ram . i always scan for virus and i do defragment and disc clean up utlility
Old 02-03-2005, 01:39 AM   #7 (permalink)
swatkat's Avatar
try this tweak...
Right Click the FireFox icon in DeskTop or QuickLaunch or StartMenu and click Properties....
Then click "ShortCut" Tab, and here in "Target" field add this /prefetch:1 (outside double quotes)
for example,
"C:\Program Files\Mozilla Firefox\firefox.exe" /Prefetch:1
note that there is a SPACE between " and /......
swatkat is offline
- by Niilesh
