Re: Port forwarding UT-304R2
correct me if i am wrong but isn't 192.168.1.1 the ip address of the router itself? type ipconfig /all at the command line to find your ip address and add that ip please. Also I think utorrent supports upnp. If so, you really don't need a configuration. Try disabling windows firewall and see if it works. If so, you will just need to create an exception rule for utorrent.
Life is too short. Have fun.
