Old 11-07-2007, 07:53 PM   #1 (permalink)
eWebGuru
ahref's Avatar
Default I am infected, unable to access registry, taskmanger need help
My lappy has got infected with some virus. I am unable to access registry, taksbar, command prompt, many exe file created in my F drive
Also my yahoo msgr is sending IM automatically to my contact list with some suspicious URL.
Please advice some solution.
Using XP Professional.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Old 11-07-2007, 08:24 PM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: I am infected, unable to access registry, taskmanger need help
First scan your computer with a kaspersky antivirus.
then use this tool to remove the restrictions.
Nokia N86 8MP
Lucky_star is offline
Old 11-07-2007, 10:19 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
boot into Safe Mode (or schedule a boot-time scan) and scan your Pc with your AV and two AntiSpys. A safe-mode or a boot-time scan is always the preferred way in case of a severe malware attack. Finish off with cleaning up your residual PC junk with CCleaner. Reboot.
if problems persist run the HijackThis Tool, and copy-paste its saved log-file in www.hijackthis.de
click Folder Options Missing ? Task Manager Disabled ? Regedit Disabled ?
RRT and TaskManager Fix are two utilities which can help you address such issues easily.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Infected Registry Problem Ecko Software Q&A 1 10-06-2007 09:48 PM
Unable to Access hi5 account nitish_mythology QnA (read only) 6 30-04-2007 07:18 AM
Unable to access Registry Editing ashwin_ka Software Q&A 6 25-01-2007 02:01 PM
Unable to access E:\ vish Software Q&A 4 06-05-2006 11:22 AM
unable to access registry editor window tkprakash Open Source 1 29-09-2005 05:26 PM
- by Niilesh
